New Parts for LGEO Library - Printable Version
+--- Thread: New Parts for LGEO Library (/thread-16260.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
Re: New Parts for LGEO Library - Sven v. Beuningen - 2015-12-04
I also tried radiosity, but with multiple light sources. This didn't worked our very well. With only on light source, I've got nice results.
I experimented with radiosity allready in the beginning, but I didn't came to a good result. With the new settings it feels promising so far. I'll start over render everything again, because of better results. I expect less problematic parts, since the problem with the faces seems to be solved now Smile.
So Long
Sven
Re: New Parts for LGEO Library - Sven v. Beuningen - 2016-02-21
Hi Damien,
I'd like to send you a PM, but can't find something like this in this foum. Is there a way how I can contact you?
So long
Sven
Re: New Parts for LGEO Library - Damien Roux - 2016-02-21
damien___(at)hotmail.com
Re: New Parts for LGEO Library - Damien Roux - 2016-02-28
Update: 2016/02/28
[Image: v25-1.jpg]
286: Minifig Suitcase Joiner Tab
336: Technic Pneumatic Cylinder 2 x 2 Piston Rod 5.5L
337: Technic Pneumatic Cylinder 2 x 2 Piston Rod 4L
757: Hose Flexible 12L Top 1 x 1 x 2/3 with Stud
2435: Plant Tree Pyramidal 3 x 3 x 4
2437: Windscreen 3 x 4 x 1 & 1/3
2489: Barrel 2 x 2 x 1.667
3003p0a: Tile 1 x 8 with White Winged Lion Pattern
3081a: Window 1 x 2 x 2 Classic with Solid Studs
3081ac01: Window 1 x 2 x 2 Classic with Solid Studs (Complete)
3081b: Window 1 x 2 x 2 Classic with Long Sill
3081bc01: Window 1 x 2 x 2 Classic with Long Sill (Complete)
3081c: Window 1 x 2 x 2 Classic with Short Sill
3081cc01: Window 1 x 2 x 2 Classic with Short Sill (Complete)
3082: Window 1 x 2 x 2 Classic Glass
3587: Tail 2 x 5 x 3.667 Plane
3626bpw1: Minifig Head with Thick Moustache, Angry Eyes, Wavy Mouth, Long Hair and Stubble Pattern
3626c: Minifig Head with Closed Hollow Stud
3861: Door 1 x 4 x 5 with Panes
3899: Minifig Cup
4162p10: Tile 1 x 8 with "Venice" Pattern
4449: Minifig Suitcase
4449c01: Minifig Suitcase Open
4466: Exhaust Pipe Twin Inlet 11L Left
4467: Exhaust Pipe Twin Inlet 11L Right
4528: Minifig Frypan
4617: Propellor 3 Blade 5.5 Diameter with Technic Peghole
4617a: Propellor 3 Blade 5.5 Diameter with Freestyle Pinhole
4617b: Propellor 3 Blade 5.5 Diameter with Technic Peghole
14417: Plate 1 x 2 with Ball Joint-8
14769p06: Tile 2 x 2 Round with Round Underside Stud with Black and Dark Bluish Grey Grid Pattern
22961: Technic Axle with Perpandicular Pin Hole
32474: Technic Ball Joint with Axlehole Blind
42610: Wheel Rim 8 x 11.2 with Centre Groove
44674: Car Mudguard 3 x 4 Overhanging
49668: Plate 1 x 1 with Tooth In-Line
50943: Car Engine 2 x 2 with Air Scoop
56890: Tyre 12/57 x 10 Balloon
62361: Car Mudguard 6 x 1.5 x 1 with Arch
88393: Brick 1 x 2 x 5 with Groove
90398: Minifig Statuette
92690: Bar 1L with Top Stud and Two Side Studs
821472hc01: Sticker 1.0 x 2.8 with Black and Light Grey Grid on Transparent Background (Right) (Formed)
821472ic01: Sticker 1.0 x 2.8 with Black and Light Grey Grid on Transparent Background (Left) (Formed)
RE: New Parts for LGEO Library - Damien Roux - 2017-04-04
Update: 2017/04/05
[Image: v26-1.jpg]
2572: Panel 6 x 6 x 9 with Curved Top
2578b: Brush Holder Street Sweeper with Hinge Bottom
3069bp01: Tile 1 x 2 with Letter Pattern
3935: Wing 4 x 4 Right
3936: Wing 4 x 4 Left
4162p11: Tile 1 x 8 with "Berlin" Pattern
4162p12: Tile 1 x 8 with "New York City" Pattern
4162p13: Tile 1 x 8 with "United States Capitol Building" Pattern
4162p14: Tile 1 x 8 with "Buckingham Palace" Pattern
4865bp01: Panel 1 x 2 x 1 with Rounded Corners with Brick Wall and Tunnel Pattern
4865bp02: Panel 1 x 2 x 1 with Rounded Corners with Light Blue Sky and Grey Skyline Pattern
4865bp03: Panel 1 x 2 x 1 with Rounded Corners with Light Blue and Green Arrows on Tan Background Pattern
6027: Animal Dragon Head
6028: Animal Dragon Tail
6141: Plate 1 x 1 Round
6184: Arch 1 x 12 x 5 with Curved Top
18674: Plate 2 x 2 Round with 1 Centre Stud
21229: Fence Spindled 4 x 4 x 2 Quarter Round with 3 Studs
30044: Window 1 x 2 x 2.667 with Rounded Top
30046: Window 1 x 2 x 2.667 Pane Lattice Diamond with Rounded Top
30056: Fence Spindled 4 x 4 x 2 Quarter Round with 2 Studs
30167: Minifig Hat Wide Brim Flat
43719: Wing 4 x 4 with 2 x 2 Cutout
51011: Tyre 6.4/75 x 8 Shallow Offset Tread
51739: Wing 2 x 4
60849: Minifig Hose Nozzle with Side String Hole Simplified
86500: Dome 4 x 4 Smooth
87617: Cylinder 1 x 1 x 4.333 with Handle
88293: Brick 3 x 3 x 2 Round Corner with Dome To
92947: Brick 2 x 2 Round with Grille
99780: Bracket 1 x 2 - 1 x 2 Up
99781: Bracket 1 x 2 - 1 x 2 Down
RE: New Parts for LGEO Library - Damien Roux - 2017-09-02
Update: 2017/09/03
[Image: v27-1.jpg]
2431pz0: Tile 1 x 4 with Black Utility Belt Pattern
2431pz1: Tile 1 x 4 with Black and Light Yellow Triangle on Red Rectangle Pattern
2599: Minifig Flipper
3003p0b: Tile 1 x 8 with Gold and White Big Ben Clock Face Pattern
3004pz0: Brick 1 x 4 with Bright Green Tie with Bright Light Orange Skulls Pattern
3010pz0: Brick 1 x 4 with Batman Logo in Yellow Oval Pattern
3010pz1: Brick 1 x 4 with Yellow Batgirl Logo with Black Border Pattern
3010pz2: Brick 1 x 4 with Yellow Colar and Yellow Robin Logo Pattern
3010pz3: Brick 1 x 4 with Black Line, Light Orange Skull and Magenta Pockets Pattern
4162p15: Tile 1 x 8 with "THE SOLOMON R GUGGENHEIM" Pattern
4162p16: Tile 1 x 8 with "Sydney" Pattern
4162p17: Tile 1 x 8 with "Chicago" Pattern
4162p19: Tile 1 x 8 with "London" Pattern
11090: Bar Tube with Clip
11208: Wheel Rim 10 x 14 with Fake Bolts and 6 Spokes
11458: Plate 1 x 2 with Offset Peghole
11476: Plate 1 x 2 with Clip Horizontal on Side (Thick C-Clip)
11477: Slope Brick Curved 2 x 1
15068p05: Slope Brick Curved 2 x 2 x 0.667 with "MUSEUM" Text Pattern
15070: Plate 1 x 1 with Tooth Perpandicular
15208: Plate 1 x 2 with 3 Teeth In-Line
15209: Tile 1 x 2 with 2 Teeth Vertical
15395: Dome 2 x 2 Inverted with Stud and Tube
15397: Plate 3 x 3 Cross
15571: Slope Brick 45 1 x 2 Triple with Bottom Stud Holder
18649: Plate 1 x 2 with Handles on Opposite Ends
18654: Technic Beam 1
18677: Plate 1 x 2 with Offset Peghole on Underside
18976: Wheel Rim 11 x 18 with Vented Disc Brake
22385: Tile 3 x 2 with Angled End
22388: Slope Brick 50 1 x 1 x 0.667 Quadruple
22885: Brick 1 x 2 x 1.667 with Studs on 1 Side
23443: Bar Tube with Handle
23950: Panel 1 x 3 x 1 with Rounded Corners
24246: Tile 1 x 1 with Rounded En
24299: Wing 2 x 2 Left
24307: Wing 2 x 2 Right
24309: Slope Brick Curved 3 x 2
25269: Tile 1 x 1 Corner Round
25866c02: Figure Friends Lipstick with White Handle
26603: Tile 2 x 3
26604: Brick 1 x 1 with Studs on Two Adjacent Sides
30340: Minifig Life Ring
32294: Technic Suspension Arm 1 x 9 x 2.5
45677: Wedge 4 x 4 x 0.667 Curved
48729b: Bar 1.5L with Clip with Truncated Sides and Hole in Shaft
50745: Car Mudguard 4 x 2.5 x 2
50950: Slope Brick Curved 3 x 1
50990a: Dish 10 x 10 Inverted with Hollow Studs
50990b: Dish 10 x 10 Inverted with Solid Studs
55707c: Minifig Batarang
61409: Slope Brick 18 2 x 1 x 2/3 Grille
61678: Slope Brick Curved 4 x 1
64727: Bar 0.5L with Blade 3L
86208: Minifig Torch without Grooves
87079pz0: Tile 2 x 4 with Groove with Brickheadz Series Number "1"
93606: Slope Brick Curved 4 x 2
95108: Friends Lipstick Handle
95109: Friends Lipstick Core
98138: Tile 1 x 1 Round with Groove
98138p07: Tile 1 x 1 Round with Eye Pattern
98138pz0: Tile 1 x 1 Round with Two White Squares Pattern
99774: Minifig Ski 4L without Hinge
RE: New Parts for LGEO Library - Damien Roux - 2018-02-05
Update: 2018/02/05
[Image: v28-1.jpg]
11209: Tyre 10/32 x 14
11291: Wedge 3 x 4 x 0.666 Cutout
18977: Tyre 11.2/28 x 17.6 Intermediate
2431pz2: Tile 1 x 4 with Black Lines and Medium Azure and White Half Circle Pattern
2431pz3: Tile 1 x 4 with Black Moustache Pattern
25214: Cylinder 2 x 2 Elbow with Axle Holes
2530: Minifig Sword Cutlass
30028: Tyre 8/40 x 8 Slick Smooth
30031: 30031: Minifig Handlebars
3004pz1: Brick 1 x 2 with Collar and Tan Skin Pattern
3010pz4: Brick 1 x 4 with 3 Dark Red Vertical Stripes Pattern
3010pz5: Brick 1 x 4 with Silver Star and 2 Belt Buckles Pattern
3010pz6: Brick 1 x 4 with Black Pectoral SPAM CONTENT Pattern
3010pz7: Brick 1 x 4 with Black Abdominal SPAM CONTENT Pattern
3069bpz0: Tile 1 x 2 with Black Lines and Medium Azure and White Circles Pattern
3069bpz1: Tile 1 x 2 with Silver Rectangles and Medium Azure Trapezoid Pattern
3069bpz2: Tile 1 x 2 with 3 Dark Red Waves Pattern
3070bp00: Tile 1 x 1 with White Top Square Pattern
3176: Plate 3 x 2 with Hole
32014: Technic Angle Connector #6 (90 degree)
32015: Technic Angle Connector #5 (112.5 degree)
32016: Technic Angle Connector #3 (157.5 degree)
32034: Technic Angle Connector #2 (180 degree)
32192: Technic Angle Connector #4 (135 degree)
3245a: Brick 1 x 2 x 2
3245b: Brick 1 x 2 x 2 with Inside Axleholder
3245c: Brick 1 x 2 x 2 without Understud
3245cpz0: Brick 1 x 2 x 2 without Understud with Black, Silver and Red Jacket Pattern
3299: Slope Brick 33 2 x 4 Double
3622pz0: Brick 1 x 3 with Dark Red Lines, Brown Belt and Dark Nougat Buckle Pattern
3749: Technic Axle Pin
40379: Animal Tail Section End
4083: Bar 1 x 4 x 2 with Studs
42446: Bracket 1 x 1 - 1 x 1
43720: Wedge 4 x 2 Sloped Right
43721: Wedge 4 x 2 Sloped Left
43857: Technic Beam 2
50946: Car Grille 2 x 2.5 x 3 with Sloped Front
6005: Arch 1 x 3 x 2 with Curved Top
62360: Windscreen 3 x 6 x 1 Curved
6536: Technic Cross Block 1 x 2 (Axle/Pin)
6562: Technic Axle Pin
75902: Minifig Shield Round Bowed
75902p02: Minifig Shield Round Bowed with Bullseye with Star Pattern
87079pz1: Tile 2 x 4 with Groove with White "A" and 4 Black Lines Pattern
88930: Slope Brick Curved 2 x 4 with Underside Studs
88930pz0: Slope Brick Curved 2 x 4 with Black Line and Dark Red Rectangle Pattern
RE: New Parts for LGEO Library - Michael Horvath - 2018-02-07
I am rendering an old LGEO scene, but with your new parts library. When I try to render the scene it quits when it asks for "lg_2582_slope" which it can't find. Do you know what might be the issue? Thanks.
//// Part 2582.dat
#ifndef (_2582_dot_dat)
#if (L3Quality > 0)
    #ifndef (lg_2582)
        #include "lg_2582.inc"
    #end
#end
#declare _2582_dot_dat = #if (L3Quality = 0) box { <-40,-4,-30>, <40,72,10> } #else object {
// Hinge Panel  2 x  4 x  3 & 1/3
    lg_2582
    transform L3LgeoToLDraw
#end
#declare _2582_dot_dat_clear = #if (L3Quality = 0) box { <-40,-4,-30>, <40,72,10> } #else object {
    lg_2582_clear
#end
#if (L3Quality > 0)
#declare _2582_dot_dat_slope = object {
    lg_2582_slope
#end
#end // ifndef (_2582_dot_dat)
The model was generated using L3P.exe.
RE: New Parts for LGEO Library - Damien Roux - 2018-02-07
(2018-02-07, 12:44)Michael Horvath Wrote: I am rendering an old LGEO scene, but with your new parts library. When I try to render the scene it quits when it asks for "lg_2582_slope" which it can't find. Do you know what might be the issue?
It might be a typo in my files, I will investigate and let you know asap.
OK, I see the problem.
Historically LGEO considers 2582 as a "slope" part, with a grainy surface.
Apparently I didn't consider it as a "slope" part.
The question is : has that part a grainy surface or not?
I can't answer as I don't own it.
After a few search on the web, I would say that this part is not grainy.
Only a pattern version is.
[Image: s-l1600.jpg]
If someone can confirm this, that would be great.
