New Parts for LGEO Library - Printable Version
+--- Thread: New Parts for LGEO Library (/thread-16260.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
Re: New Parts for LGEO Library - Johannes Schauer - 2015-11-23
Damien Roux Wrote:But, I'm 100% sure they are not up to date and are not the same as they where released with the first LGEO library (I have surely modified them for my own pupose).
Many thanks. A rendering using Leocad and this file looked fine to my eyes. Could you include that file in your next release? I'm sure if there are problems with it, people will submit their fixes.
Thanks!
Re: New Parts for LGEO Library - Sven v. Beuningen - 2015-11-26
Hi Damien,
I found a guy who might need some love on the normals. Can you help on that?
Please see the attached image.
So long,
Sven
Re: New Parts for LGEO Library - Damien Roux - 2015-11-28
Update: 2015/11/28
[Image: v24-1.jpg]
4289 - Boat Mast 2 x 2
4867 - Tail Plane
47755 - Wedge 4 x 3 Curved with 2 x 2 Cutout
48171 - Technic Brick 2 x 2 with Hole, Half Rotation Joint Ball Vert
48729 - Bar 1.5L with Clip
57518 - Technic Chain Tread 38
57520 - Technic Sprocket Wheel 25.4
59230 - Minifig Mechanical Arm Straight
60470 - Plate 1 x 2 with Clips Horizontal (Open U-Clips)
60470a - Plate 1 x 2 with Clips Horizontal (Open U-Clips)
60470b - Plate 1 x 2 with Clips Horizontal (Thick C-Clips)
60592 - Window 1 x 2 x 2 without Sill
60601 - Glass for Window 1 x 2 x 2 without Sill
62712 - Brick 2 x 2 with Ball Socket and Axlehole
64276 - Technic Beam 2 Liftarm with Ball Joint
87079 - Tile 2 x 4 with Groove
87079p08 - Tile 2 x 4 with Black "WALL" Pattern
90195 - Panel 1 x 2 x 2 Hollow Stud with Arched Windows Opening
92013 - Brick 2 x 2 with Ball Socket and Axlehole
98282 - Car Mudguard 4 x 2.5 x 1
98286 - Hinge Plate 2 x 4.5 Top with Technic Pin Hole
99021 - Technic Pneumatic Hose Connector with Bush
u66 - Sheet Plastic 6 x 12 Triangular
u66c01 - Sheet Plastic 6 x 12 Triangular (Formed Shape 1)
u66c01 - Sheet Plastic 6 x 12 Triangular (Formed Shape 2)
u66p01 - Sheet Plastic 6 x 12 Triangular with Blue and Red Triangles and Blue Lines Pattern
u66p01c01 - Sheet Plastic 6 x 12 Triangular with Blue and Red Triangles and Blue Lines Pattern (Formed Shape 1)
u66p01c02 - Sheet Plastic 6 x 12 Triangular with Blue and Red Triangles and Blue Lines Pattern (Formed Shape 2)
u151 - Rubber Belt Square 15 / 1.2
Strange you got those faces.
I tried to render that part and it was completely smooth for me.
I've updated the normals anyway, you can redownload the package
I wrote on my first post in this topic :
you can use my own lg_defs.inc provided in the package (but it might conflict with Owen's one on some parts)
This is exactely what happened here.
2 solutions here :
- you get AIOI's lg_defs.inc file and you manually add the two lines for matrix transformation (see my first post)
- you wait until I make my library 100% complient with Owen's part.
Re: New Parts for LGEO Library - Sven v. Beuningen - 2015-11-30
And again thank you for the new parts. Some of them I've already rendered, but the new versions have better quality. So I'm gonna render them again.
So Long
Sven
Have tried rendering the part with some area lights? Without are lights it looks almost smooth.
There are some parts in the library where I've seen similar issues. I suggest, that I collect them and provide a list after I rendered all parts for the first time.
I also have seen some parts where I think that something with the bounding box is not right and therefor calculating full view (ctrl+f) in LDview does not work. I can also add them to the overview if you like.
Best Regards
Sven
Re: New Parts for LGEO Library - Philippe Hurbain - 2015-11-30
Maybe it would be time to start another thread? this one is a nightmare to follow because of all the images... (and deep indentation level!)
Re: New Parts for LGEO Library - Damien Roux - 2015-11-30
I was planning to start a new topic when my parts would be released with the AIOI. As it takes more timw than expected, I will creaze a new one for next parts release.
Did the updated 4589 part still give normals problems?
Could you send me a pov files where you get those facetization?
And yes, if you have a list of parts giving problems, It would be perfect.
