New Parts for LGEO Library - Printable Version
+--- Thread: New Parts for LGEO Library (/thread-16260.html)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
Re: New Parts for LGEO Library - Michael Horvath - 2015-09-22
Just a heads up: the sub-surface scattering feature of UberPOV requires nearly all materials to have an ior. I'm not sure what the proper values are for metal, pearl, rubber, etc. though.
Re: New Parts for LGEO Library - Sven v. Beuningen - 2015-10-27
Hallo together,
I read the hole post and are quite interessted in Lego brick rendering. First of all I'd like to thank you for the work to provide the high quality parts for rendering.
I tried to do the setup like described in the first post, but I'm not quite sure if I did it right. Since I'm not very familiar with PovRay I have the question about the following step in the introduction:
Damien Roux Wrote:You may want to put the lg_xxxx.inc files in your usual LGEO directory and the xxxx.inc files in another folder (don't forget to declare it in PovRay or it will not find the requested files)
I did the first step and created a directory called "parts" in my LGEO directory and copied all xxxx.inc files there. What I'm missing is the last part. How to I tell PovRay to look for the files in that location?
I tried to render a part without adding the directory somewhere and I got a rendered brick, but where is the difference if I add the directory? Do the bricks look different?
Best Regards
Sven
Re: New Parts for LGEO Library - Damien Roux - 2015-10-27
I suggested to create a new folder to avoid messing up everything as what I provide is still WIP. But if you copy all my files in your LGEO directory it will produce the same result.
You can tell PovRay to use other directory by editing the povray.ini file.
Re: New Parts for LGEO Library - Sven v. Beuningen - 2015-10-28
Hi Damien,
thank you very much. This was easy.
By the way: Currently I load the .ldr files in LDView, zoom to fit "ctrl+f" and export the povray file. Is there a more easy way to "convert" a ldr file to a povray file? As far as I know there is no way to script LDView to do this. Currently I use a python script which starts LDView, sends the keys and closes LDView again. It would be very cool, if someone knows a nicer way.
Best Regards
Sven
Re: New Parts for LGEO Library - Damien Roux - 2015-10-28
With ldview there is no other way at the time.
Hi Damien,
I'm not bound to LDview. I just picked it as a first approach, since it works somehow. Is there another way known without LDview?
Best Regards
Sven
Maybe L3P but it's kinda outdated
Ok thank you. Then I think I'll stick with LDView for now.
Re: New Parts for LGEO Library - Jonas Hall - 2015-11-10
Awesome work!!!
I would like to request a part for any coming update (if there's going to be any).
It is part "4867 Tail Plane" (see link http://brickset.com/parts/4188568)
I can't seem to find it anywhere, so chances are that it doesn't exist as an include file for the LGEO library yet.
Re: New Parts for LGEO Library - Damien Roux - 2015-11-11
Update: 2015/11/12
[Image: v22-1.jpg]
973p2d - Minifig Torso with Windsurfboard Pattern
973p64 - Minifig Torso with Spyrius Pattern
2362b - Panel 1 x 2 x 3 with Hollow Studs
2446p51 - Minifig Helmet Modern with Black, Blue and Silver Unitron Pattern
2739a - Technic Steering Link 6L Type 1
2852 - Technic Engine Connecting Rod
3068bp0d - Tile 2 x 2 with Black Dot and White "E" on Red Disc Pattern
3068bpc1 - Tile 2 x 2 with Yellow Horizontal Stripes and "SOLAR CHARGE LEVEL" Pattern
3626bp03 - Minifig Head with Standard Grin Pattern
3626bp68 - Minifig Head with Silver Sunglasses and Red Headset Pattern
3678 - Slope Brick 65 2 x 2 x 2 without Centre Tube
3678a - Slope Brick 65 2 x 2 x 2 without Centre Tube
3678b - Slope Brick 65 2 x 2 x 2 with Centre Tube
3857 - Baseplate 16 x 32 with Square Corners
4162p0z - Tile 1 x 8 with "Louvre" Pattern
4507 - Hinge Plate 1 x 6 with 2 and 3 Fingers On Sides
4515 - Slope Brick 10 6 x 8
4864ap04 - Panel 1 x 2 x 2 with Palm Tree Pattern
6041 - Propellor 3 Blades 3.5 Diameter
6075 - Minifig Surf Board 2 x 10
6083 - Panel 3 x 8 x 7 Rock Triangular
6255 - Plant 1 x 1 x 0.667 Round with 3 Large Leaves
14719 - Tile 2 x 2 Corner
15712 - Tile 1 x 1 with Clip (Thick C-Clip)
30162 - Minifig Tool Binoculars Town
30375 - Minifig Mechanical Torso
32005 - Technic Steering Link 6L Type 2
32187 - Technic Transmission Driving Ring Extension
32250 - Technic Beam 3 x 5 x 0.5 Liftarm Bent 90 Quarter Ellipse
32529 - Technic Pin Joiner Plate 1 x 2 x 1 & 1/2
41763 - Slope Brick Curved 6 x 1 Inverted
41764 - Wedge 2 x 6 Double Inverted Right
41765 - Wedge 2 x 6 Double Inverted Left
42023 - Slope Brick Curved 6 x 1 Inverted
45590 - Technic Axle Joiner Double Flexible
47455 - Technic Brick 2 x 2 with Hole, Half Rotation Joint Ball Vert
47457 - Slope Brick Curved 2 x 2 x 2/3 Triple with Two Top Studs
