Cannot rotate on a specified angle - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Help (https://forums.ldraw.org/forum-13.html) +--- Thread: Cannot rotate on a specified angle (/thread-15547.html) |
Cannot rotate on a specified angle - MotoR - 2015-02-10 Hello! How to rotate a part (for example a technic part) on a specified angle? The checkbox "Use rotation vector values" in the "Position & Orientation" window is disabled and the Edit Bar rotates the part only with a some step
Re: Cannot rotate on a specified angle - Roland Melkert - 2015-02-10 You are talking about the known MLCad bug, discussed here http://forums.ldraw.org/showthread.php?tid=6132&pid=6132#pid6132 As far I know there is no workaround besides changing the grid stepping. Alternative would be to use another editor (e.g. my LDCad ) to rotate the part(s) and afterwards you continue in MLCad as normal.
Re: Cannot rotate on a specified angle - MotoR - 2015-02-11 LDCad don't work. I see only red crosses instead my model. Re: Cannot rotate on a specified angle - Roland Melkert - 2015-02-11 That happens when it can't find the LDraw library, did you point it to the correct location at first start up? The LDraw folder is usually at 'C:\Users\Public\Documents\LDraw" or something similar. You can change it afterwards using the prefs -> ldraw search locations dialog (select the 'official' library item and change it's folder). |
