Most frequently used parts ? - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: Most frequently used parts ? (/thread-14791.html) |
Most frequently used parts ? - Magnus Forsberg - 2014-12-03 Following the creation of this list, I now wonder what parts I should rework first. Is there some way to compare the list of non-BFC'd parts with a list of the most frequently used parts? The only site I know of that have part statistics is this page at Rebrickable, but it only lists the 8 most common parts. I've recently cleaned more monorail parts, but how often are these parts used? I don't want to spend time on a part that is rarely used. Re: Most frequently used parts ? - Gerald Lasser - 2014-12-03 I picked a car door, can you check if it is fine? I would do more then (ignore the MLCAD remains for now) Gerald Re: Most frequently used parts ? - Max Martin Richter - 2014-12-03 Looks good. It just need to run through rectifier. ;-) /Max Re: Most frequently used parts ? - Gerald Lasser - 2014-12-03 Alright, I just took the part as is and reordered the triangles to be BFC..., but I can see the benefit of "rectifying" it :-) |
