Official parts with errors/typos - Printable Version
+--- Thread: Official parts with errors/typos (/thread-14501.html)
Official parts with errors/typos - Mario Pascucci - 2014-11-09
Hi all.
Working on coding some Java libraries to handle LDraw libraries I hit some parts with errors. Following a brief list with errors/typos I found:
* 3842a.dat uses BFC CERTIFY INVERTNEXT
* 3842b.dat uses BFC CERTIFY INVERTNEXT
* s\3068s101.dat uses color 391 (unknown)
* 973psk.dat uses color 391 (unknown)
* 4150p02.dat uses color 354 (unknown)
* 973p7b.dat uses color 354 (unknown)
* s\2528s01.dat at line 385 there is a triangle with 4 vertices
* s\6582a.dat all quads are "bow-tied"
* s\6582b.dat all quads are "bow-tied"
* s\6580a.dat all quads are "bow-tied"
* s\6581a.dat all quads are "bow-tied"
* s\6594a-c.dat all quads are "bow-tied"
* s\6595a-d.dat all quads are "bow-tied"
* 2907.dat some quads are "bow-tied"
* s\6579a.dat all quads are "bow-tied"
HTH
Mario
Re: Official parts with errors/typos - Mario Pascucci - 2014-11-26
Hi all.
Part 3678b.dat "Slope Brick 65 2 x 2 x 2 with Centre Tube" uses wrong "tube" on bottom.
Tube using "stud2a.dat" but its size is wrong (should be "stud4a.dat"?). Checked on Bricklink, LDD and LDraw editor (no check in real part, I don't have one).
Attached screenshot file shows 3678b (right, with green selection box) and 3003 (left) to compare underside tubes.
Mario
Re: Official parts with errors/typos - Max Martin Richter - 2014-11-26
Thanks for spotting this. I'll check this evening.
Part is corrected. and sent to our admin. He will load it to the PT... It is on PT...
Re: Official parts with errors/typos - Mario Pascucci - 2014-11-27
Thank you Smile
Mario
Re: Official parts with errors/typos - Mario Pascucci - 2015-01-12
Hi all.
While building this, I noticed that metal detector (part #4479.dat) bar seems too large. Part file reports scale of 6 but I think correct value is 4.
Mario
Re: Official parts with errors/typos - Magnus Forsberg - 2015-01-12
Yes, it is wrong. And a comparition with LDD data reveals even more issues.
This part is currently present at the PT, so these issues can be fixed now.
trans-red is ldraw. green is LDD
Re: Official parts with errors/typos - Mario Pascucci - 2015-03-24
One more:
Part 6216.dat (Brick 2 x 4 x 2 with Curved Top)
Underside "stud3a.dat" and reinforcing internal ribs are 1.5 LDU too short. Internal "stud4a.dat" is correct.
Mario
Re: Official parts with errors/typos - Mario Pascucci - 2015-04-14
Part 6082 "Panel 4 x 10 x 6 Rock Rectangular"
"stud3a.dat" on opposite sides are 4LDU too short.
ldd.png shows LDD model image
ldraw.png shows LDraw model
PS: can I submit correct models? How can I do?
Thank you
Mario
Re: Official parts with errors/typos - Gerald Lasser - 2015-04-14
see here: http://www.ldraw.org/library/tracker/
To submit parts, you must be authorized as an author on the Parts Tracker and have read and affirmed the Contributor Agreement.
To become authorized as an author you must first register with the LDraw.org Forum (it's free) and then send an email to the Parts Library Admin (Chris Dee) with your true first and last names and your LDraw.org username. You must also include the statement "I accept the LDraw.org Contributor Agreement with regards to all past and future contributions I make to LDraw.org".
and here: http://www.ldraw.org/cgi-bin/tracker/submit.cgi
To submit a fix for an existing part, email the file to [email protected], and it will be manually posted to the tracker.
Thank you Gerald for your quick reply Smile
Mario
Re: Official parts with errors/typos - Ronald Vallenduuk - 2015-07-07
These 3 parts have a naming issue:
87994.dat Bar 3L
87994p01.dat Bar 3L with White Ends Pattern
2714.dat Bar 7.6L with Stop
All three should have 2 spaces between Bar and the length like 30374 and all other single-digit length bars.
The geometry of the 9V points (2859 & 2861) is wrong; the end of the branching track is slightly off where it should be. They also have issues with gaps and overlaps.
I've started work on their PF counterparts. Once they're done I might fix these.
Re: Official parts with errors/typos - Chris Dee - 2015-07-09
I have corrected the Bar descriptions on the Parts Tracker.
Re: Official parts with errors/typos - Magnus Forsberg - 2015-07-26
I'm making more Stormtrooper torsos and started looking at the other patterned part for the trooper.
Is this helmet correct, or is this a 'misprint'?
[Image: x130px2.jpg?0]
IMO the divided look of the 'mouth' is a misprint, and our current version of the helmet should be changed.
The pattern seams to be printed in two sections. One left side and one right side stencil that happened to be very misaligned on the part that was used as a reference when 30408p01 was made.
[Image: 7139-4.jpg]
The headdresses 90462 and 30168 are both placed to low. They need to be lifted by 2 ldu.
Best seen from behind. The backside/bottom is placed inside the torso.
Re: Official parts with errors/typos - Magnus Forsberg - 2015-11-17
The Tile+Sticker shortcut 2431d01 has a bad origin. It is placed 1 ldu above the surface of the brick.
0 Tile  1 x  4 with Black "POLICE" and Red Line Sticker
0 Name: 2431d01.dat
0 !LDRAW_ORG Shortcut UPDATE 2012-01
0 !KEYWORDS set 6398
1 16 0 1 0 1 0 0 0 1 0 0 0 1 2431.DAT
1 16 0 1 0 1 0 0 0 1 0 0 0 1 821410c.dat
A corrected version is sent to Admin, but how do we handle the change in origin best?
Re: Official parts with errors/typos - Philippe Hurbain - 2015-11-18
A "a" version + ~moved to?
Re: Official parts with errors/typos - Steffen - 2015-12-18
I suggest instead
- obsoletizing the ...d01 shortcut
- creating a new ...d02 with correct position
Re: Official parts with errors/typos - Philippe Hurbain - 2015-12-18
Makes sense too...
Re: Official parts with errors/typos - Magnus Forsberg - 2015-12-18
It has already been done by our excellent Admin at 2431d02 and 2431d01.
Re: Official parts with errors/typos - Merlijn Wissink - 2016-01-08
I'm not sure if this is the 'correct' topic for this, but I noticed these 2 different patterned parts represent the same physical part: 3068bp14 and 3068bp31 both seem to be 3068bpb0148.
There is a color difference between the two files, but I can't seem to find information about 2 versions. To me, it looks like 3068bp14 has the best colors.
Re: Official parts with errors/typos - Magnus Forsberg - 2016-01-08
I think this is the third time the same error is reported. Might be time to correct it now....
Recently here, but the first time here
I'll follow the info from JC Tchang to Philo, and update the parts and send them to PTAdmin.
Re: Official parts with errors/typos - Magnus Forsberg - 2016-03-05
The 2x4 wing 51739 is not correct. It should be possible to place two of them next to each other.
I'm reworking it, and also creating the new 2x2 wing.
RE: Official parts with errors/typos - Magnus Forsberg - 2016-11-14
A new and reworked version of 4479 is now present at the PT as 4479a.dat
[Image: 4479a.png]
RE: Official parts with errors/typos - Magnus Forsberg - 2017-04-03
I think the ball on these two parts are too small.
[Image: 30082.gif?0][Image: 30395.png]
30082                                                     30395
They should fit inside any of the towball socket parts, but are only 14 ldu, intead of 16 ldu.
Would it be OK to simply resize the ball, or do they need to be renumbered too.
RE: Official parts with errors/typos - Magnus Forsberg - 2018-11-06
I think the angle of the barrel on the two guns in the batman accessories pack 55707a-55707e are wrong.
.png   Image 1.png (Size: 21.25 KB / Downloads: 33)
TrRed is ldd part 62885. Blue is ldraw part 62885. Yellow is ldraw part 55707a.
TrRed is ldd part 85973. Yellow is ldraw part 55707b.
At Bricklink 62885 is described as similar in mold to bb192 (a part included in 55707, only difference is the length of the barrel)
At Bricklink 85973 is described as similar in mold to x1608 (a part included in 55707)
https://www.bricklink.com/catalogItemInv.asp?P=55707
I don't have any of the 55707 accessories, but I do have the newer parts. I tried to measure the angle of the Tommy gun, and think it should be the same as in ldraw part 62885, 17 degrees. Not 26,81 as in 55707b
