1-16chrd, an interesting idea... - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: 1-16chrd, an interesting idea... (/thread-14500.html) |
Re: 1-16chrd, an interesting idea... - Magnus Forsberg - 2015-01-05 I think '4-4ering' is an answer to Philo's question above. I like that suggestion. One file, containing a set of 16 x 1-16chrd, to be use once in a round tile. Re: 1-16chrd, an interesting idea... - Damien Roux - 2015-01-06 Yes, it was an answer to Philo's question! Re: 1-16chrd, an interesting idea... - Philippe Hurbain - 2015-01-06 Now on PT... http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=p/4-4ering.dat Re: 1-16chrd, an interesting idea... - Magnus Forsberg - 2015-01-10 I think we could use this primitive to prevent gaps around any 16-sided, non-primitive based, design. I tried adding a 4-4ering to the recently changed Rims 93595p01-p03 and it works fine. If a pattern, or subfile, made of non circular primititves, is placed inside a ring or ndis primitive there will always be gaps around it, in primititve substitution mode. This idea, the 1-16chrd and any X-Xering, will close that unwanted gap if placed correctly. It could even be used to add differently coloured areas. Re: 1-16chrd, an interesting idea... - Massimo Maso - 2015-02-14 I'm not able to visualize the 4-4ering primitive, so can you give me the correct insturction to be included, soas to complete the four parts 93595? Massimo Re: 1-16chrd, an interesting idea... - Magnus Forsberg - 2015-02-14 You need to add this to the front of the rim, sometimes coloured depending on the pattern. 1 16 0 0 -8 13 0 0 0 0 13 0 1 0 4-4ering.dat and this to the subfile s\93595s01.dat 1 16 0 0 -5 0 0 13 -13 0 0 0 -1 0 1-16chrd.dat RE: 1-16chrd, an interesting idea... - Willy Tschager - 2018-03-18 None of this is in the specs or the PT restrictions nor has it been ratified by the LSC. I do not expect reviewers to hold a part for mere suggestions in the forum. w. RE: 1-16chrd, an interesting idea... - Willy Tschager - 2018-11-15 WOULD THE PEOPLE WHO COOKED UP THIS HACK PLEASE PUT IT IN AN OFFICIAL SPEC AND ADD IT TO THE PT RESTRICTION. Thanks w. RE: 1-16chrd, an interesting idea... - Philippe Hurbain - 2018-11-15 (2018-11-15, 9:53)Willy Tschager Wrote: WOULD THE PEOPLE WHO COOKED UP THIS HACK PLEASE PUT IT IN AN OFFICIAL SPEC AND ADD IT TO THE PT RESTRICTION.Is this really necessary, since it concerns a single, already official file (empty.dat)? RE: 1-16chrd, an interesting idea... - Willy Tschager - 2018-11-15 (2018-11-15, 11:59)Philippe Hurbain Wrote: Is this really necessary, since it concerns a single, already official file (empty.dat)? It does: http://www.ldraw.org/cgi-bin/ptdetail.cgi?f=parts/14769p0b.dat And I guess this is the right place for: http://www.ldraw.org/article/512 A comment in 1-16chrd.dat with a link back to this discussion is not the way to document things. w. |
