Official part file validator - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Official File Specifications/Standards (https://forums.ldraw.org/forum-32.html) +--- Thread: Official part file validator (/thread-14401.html) |
Official part file validator - Orion Pobursky - 2014-11-04 I'd like to see an official, web based, part validator in the vein of Mike Heidemann's DAT Header program. A simple web interface where a part author can submit a part and be served back an error list and possibly a fixed, error free part. I would gladly host such an app on the LDraw.org servers. Re: Official part file validator - Santeri Piippo - 2014-11-04 Maybe even take a step further and replace the l3p checks on the PT with something like this. Unfortunately DATHeader was quite closed source last time I checked.
Re: Official part file validator - Michael Heidemann - 2014-11-04 ????? I can't remember that question! Re: Official part file validator - Roland Melkert - 2014-11-04 LDView could probably be modified to write it's finding to a log instead of it's error dialog as it's already present on the part tracker server I believe. Re: Official part file validator - Travis Cobbs - 2014-11-04 The command line LDView could indeed be modified to output warnings and errors to a log file (or stdout/stderr) with relatively little effort. Re: Official part file validator - Chris Dee - 2014-11-05 I agree. The header checking already exists as a (more or less) self-contained script on the Parts Tracker and is used the the parts update build. I have resisted including that as a mandatory check upon file submission for fear of losing parts (and part authors) for want of a few simple corrections that can be done as admin edits. But DATheader does a lot more... Re: Official part file validator - Orion Pobursky - 2014-11-05 Yes. And I want something to automate the correction process as much as possible while also being completely browser based and therefore platform independent. Streamlining the system with good, platform agnostic tools is something that needed to happen years ago. Re: Official part file validator - Chris Dee - 2014-11-05 I agree, but Mike has done a great job with DATheader in the absence of browser-based tools. Re: Official part file validator - Willy Tschager - 2014-11-05 Chris Dee Wrote:But DATheader does a lot more... nod w. Re: Official part file validator - Michael Heidemann - 2014-11-06 Please let me know the meaning of "nod". Re: Official part file validator - Philippe Hurbain - 2014-11-06 My favorite Google translater says "nicken" in German... Re: Official part file validator - Michael Heidemann - 2014-11-06 Ok, it is not an abbreviation, it is an english word - Thanks!
Re: Official part file validator - Santeri Piippo - 2014-11-06 What I'd really like to see would be a cross-platform command-line version of DATHeader that could be used for automatic checking. Print errors/warnings/notes to stdout and with a switch, write a corrected dat file to the specified file path. Such a thing could be easily enough be hooked to a web application, the parts tracker or whatever other uses there could be. EDIT: I humbly congratulate Mike on his 2^10th post. Re: Official part file validator - Michael Heidemann - 2014-11-06 Ups, so many posts already. You asked for "cross-platform command-line version of DATHeader". DATHeader is written in VB.NET. If somebody like to translate the code into "something "cross-platform" I'll help. But I can not write c or java. ![]() Edit: I just attached the sourcecode for the function ScanForHeaderErrors to this post, so you will see the bad coding behind
Re: Official part file validator - Chris Dee - 2014-11-06 I assume running through a browser is fine, so I'd prefer to convert it to Perl and incorporate it into the Parts Tracker as a replacement for the existubf L3P scrip on the Tools page. Do you have a full spec. of what DATheader current does? As I said, much of the header checking already exists. Re: Official part file validator - Michael Heidemann - 2014-11-07 A full spec. of all tests for DATHeader are currently not available because it is not necessary, I have the sourcecode ![]() The spec would have been double work. But I use an object for the header errors. Hopefully the entries are self explaining. If not, please let me know: Structure ResultHeader Dim gboolCorrectLengthofPartDescription As Boolean 'Checks for greater 1 and less max. characters. Dim gboolNoTabinPartDescription As Boolean 'Checks for Tab Character in part description Dim gboolLeadingSpacesInPartDescription As Boolean Dim gboolCorrectKeywordLength As Boolean Dim gboolCorrectKeywordUsed As Boolean Dim gboolUniqueKeywordUsed As Boolean Dim gboolCorrectHelpLength As Boolean Dim gboolPartDescriptionMatchesFilename As Boolean Dim gboolAuthorRealnameSet As Boolean Dim gboolAuthorUsernameSet As Boolean Dim gboolBFCisSet As Boolean Dim gboolLicenseisSet As Boolean Dim gboolPartTypeisSet As Boolean Dim gboolNewNotUsed As Boolean Dim gboolNeedsWorkComment As Boolean Dim gboolCategory As Boolean Dim gboolCategoryAllowed As Boolean Dim gboolKeywordsAllowed As Boolean Dim gboolPrimitive48FilenameStartwith48 As Boolean Dim gboolPrimitivePartDescriptionStartWithout_orTilde As Boolean Dim gboolSubpartFilenameStartWithS As Boolean Dim gboolPartFilenameStartwithout48orS As Boolean Dim gboolSubpartDescriptionStartWithTilde As Boolean Dim gboolSubpartDescriptionStartWithout_ As Boolean Dim gboolPartDescriptionStartWithout_ As Boolean Dim gboolShortCutPartDescriptionStartWith_ As Boolean Dim gboolShortCutFilenameContains_d_or_c As Boolean Dim gboolBFC_CCW_at_Primitive As Boolean Dim gboolNameExtensionIsDAT As Boolean Dim gboolNoSpecialCharacterInDescription As Boolean Dim gboolLineEndWithCRLF As Boolean Dim gboolRotationNotFound As Boolean 'Checks for word ROTATION Dim gboolHistoryEntryAuthorBracket As Boolean 'Checks for UserName in History Entry with Brackets Dim gboolMinifigAccessoryNotFound As Boolean ''Checks for Minifig Accessory in Filedescription Dim gboolFigureAccessoryNotFound As Boolean 'Checks for Figure Accessory in Filedescription Dim gboolSquarebracketsAroundUsername As Boolean Dim gboolAliasPartDescriptionStartWithSame As Boolean 'Checks for Alias parts to start with = Dim gboolPhysicalColorPartMentionColorInDescription As Boolean 'Checks for physical color part to mention the color [71] Dim gboolPhysicalColorPartOnlyLinetype1Used As Boolean 'Checks for physical color part only to consists of a linetype 1 Dim gboolPhysicalColorPartCorrectColorsUsed As Boolean Dim gboolAliasPartOnlyLinetype1Used As Boolean Dim gboolAliasPartOnlyOneLinetype1 As Boolean Dim gboolAliasPartOnlyColor16Used As Boolean Dim gboolAliasPartAliasMentionedInComments As Boolean Dim gboolAliasPartAliasNumberInComment As Boolean Dim gboolNoAmericanEnglishUsed As Boolean End Structure Re: Official part file validator - Orion Pobursky - 2014-11-30 I'd like to move forward on this. To all the experienced Web developers out there what is the best language solution for this? JavaScript? Perl? Something else? Re: Official part file validator - Santeri Piippo - 2014-12-04 I think a serverside solution would be the best option - you could hook that onto the Parts Tracker, so JavaScript wouldn't be a very good idea. Re: Official part file validator - Chris Dee - 2014-12-06 Yes, I was planning on Perl, as the header checking part of it is already written in Perl. Maybe I'll get some free time later this month! |
