Is POVRay still the most liked LDraw HQ renderer? - Printable Version
+--- Thread: Is POVRay still the most liked LDraw HQ renderer? (/thread-14335.html)
Is POVRay still the most liked LDraw HQ renderer? - Roland Melkert - 2014-10-30
I'm wondering... is POVRay still the most liked / preferred HQ rendering tool for LDraw scenes / animations out there?
I mean with GUI tools like blender around and all.
Just wondering in preparation of the LDCad animation HQ export feature.
Re: Is POVRay still the most liked LDraw HQ renderer? - Tore Eriksson - 2014-10-31
Yes, POV-Ray is still the unchallenged No. 1.
+ It's free.
+ It's text based = manual and scripted post-processing is possible.
+ It's quite economic with usage of system resouces.
Re: Is POVRay still the most liked LDraw HQ renderer? - Michael Klein - 2015-03-14
Well. POVRay is supporting rendering LDRAW in an easy way. I did some very time consuming research how to import LDRAW models into MODO and the speed and quality beats POVRay.
https://artstation.com/artist/virtualrepublic
Re: Is POVRay still the most liked LDraw HQ renderer? - Willy Tschager - 2015-03-14
As long as you give us just some hints how to do it:
http://forums.ldraw.org/showthread.php?tid=12940&pid=12940#pid12940
and not a "LDraw 2 MODO for dummies" kind of tutorial I usually put together on:
http://www.holly-wood.it/index-en.html
It's highly unlikely that this will ever change.
Re: Is POVRay still the most liked LDraw HQ renderer? - Orion Pobursky - 2015-03-14
While I really like your renders, MODO is not free. You're going to have a hard time convincing me to spend over 1000 USD on my part time hobby.
Re: Is POVRay still the most liked LDraw HQ renderer? - Reuben Pearse - 2015-05-14
I use POV-Ray for all my renders. I recently saw this on the POV-Ray newsgroup - this was rendered using UberPOV (an POV-Ray extension)
[Image: bricks_2015-03-04-1654.jpg]
Re: Is POVRay still the most liked LDraw HQ renderer? - Roland Melkert - 2015-05-17
This looks nice,
What is the difference between normal povray and uberray? As the github page doesn't do much explaining all I can make out it does more lighting stuff or something.
Re: Is POVRay still the most liked LDraw HQ renderer? - Damien Roux - 2015-05-17
Could you give a link to that pic on the povray forum?
This is quite interesting...
Re: Is POVRay still the most liked LDraw HQ renderer? - Willy Tschager - 2015-05-19
Really nice stuff. A short howto at the wiki would help enourmously.
Re: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2015-07-18
If I could for instance export directly to a different renderer without using Blender as a go-between I would consider switching from POV-Ray. POV-Ray is simply too slow IMO, but at the same time Blender is too convoluted IMO.
I also agree with Willy. We need a "tutorial for dummies" for us to change.
Re: Is POVRay still the most liked LDraw HQ renderer? - Damien Roux - 2015-07-18
What do you called too slow? I usually spend between one or two hours for a render in PovRay for a 1080p image and high quality radiosity turned on.
BTW I've tried uberpov with setting giving similar results as above, and here I can say it's really long. Almost ten times as more as standard Povray renders.
Re: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2015-07-19
Anything over 4-5 hours is above my limit, personally.
[edit]
This is off topic, but if you could click the 'Reply' button below the post you are responding to, it will not mess up the threaded forum view.
Re: Is POVRay still the most liked LDraw HQ renderer? - Damien Roux - 2015-07-19
Sorry for that, my forum is not set to display replies under the previous post, I kind of forget to click reply.
Re: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2015-09-06
Reuben, have you made any progress on making these settings play nice with L3P or LDView export settings?
Re: Is POVRay still the most liked LDraw HQ renderer? - Damien Roux - 2015-09-06
I did it by editing the lg_colors.inc file, and render using uberpov instead of povray. Then you can use ldview to export as usual.
You only need to add some statements in the material finish definition. Copy paste what you find in the PovRay forum post.
But I gave up using those settings as it made renders go really really long...
Re: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2015-09-07
Darats Wrote:I did it by editing the lg_colors.inc file, and render using uberpov instead of povray. Then you can use ldview to export as usual.
That is my experience as well. The renders take a long time.
Also, there are speckles on the part surfaces, and the steps you take to get rid of them make the renders take even longer.
Re: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2015-09-20
Here's my test image using many of the same settings:
[Image: 21368678879_613f61b82b_o.png]building_007_firecompany_uber_04 by Michael Horvath, on Flickr
From a distance and with a larger model the results are not so impressive.
RE: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2016-11-17
(2014-10-30, 19:13)Roland Melkert Wrote: I'm wondering... is POVRay still the most liked / preferred HQ rendering tool for LDraw scenes / animations out there?
No one has mentioned this, but there are also Sunflow and BlueRender.
Here are some Webpages to look at:
http://sunflow.sourceforge.net/index.php?pg=gall
https://www.eurobricks.com/forum/index.php?/forums/topic/113687-software-ldraw2sunflow-a-rendering-engine-for-ldraw/
https://www.eurobricks.com/forum/index.php?/forums/topic/114649-software-sunflow-for-br-bublibles-builds-tips-tricks/
https://www.eurobricks.com/forum/index.php?/forums/topic/109972-software-bluerender-a-rendering-engine-for-ldd/
One of these works for LDD models, the other works for LDraw models. I can't remember which is which, however. (Actually, I am very confused.)
You get pretty good quality renders for the time you invest in them, but the scene description language is lacking in features. And, the renderer is not-well documented in general. Sad
An example (not by me):
[Image: neo-6930.5b.png]
RE: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2018-01-30
Here's another Sunflow image that I thought looks very nice. I haven't been able to match this level of quality in my own tests, however.
[Image: 152a28d83a93f9683a51201ebe1dbb71.jpg]
RE: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2018-03-03
Yafaray has XML scene description now.
http://www.yafaray.org/development/documentation/XMLspecs
http://www.yafaray.org/community/forum/viewtopic.php?f=13&t=5007
One could bypass Blender completely and do an straight LDraw-to-Yafaray conversion, I think. Yafaray is free too. POV-Ray is just so awfully slow.... Sad
RE: Is POVRay still the most liked LDraw HQ renderer? - Roland Melkert - 2018-03-03
(2018-03-03, 11:46)Michael Horvath Wrote: Yafaray has XML scene description now.
I might give it a try for LDCad 2.x, but don't hold your breath it could take awhile Smile
RE: Is POVRay still the most liked LDraw HQ renderer? - Merlijn Wissink - 2018-03-03
But, isn't Blender good enough for rendering? Blender has been used for some pretty stunning images. Granted, they used Mecabricks instead of LDraw and Mecabricks is a lot more 'modern' so in that regard it's an unfair comparison. But my point is that Blender is a very good renderer too, so I'm wondering why you would want to 'bypass' Blender if you already got it in Blender in the first place?
(2018-03-03, 18:31)Merlijn Wissink Wrote: But, isn't Blender good enough for rendering? Blender has been used for some pretty stunning images. Granted, they used Mecabricks instead of LDraw and Mecabricks is a lot more 'modern' so in that regard it's an unfair comparison. But my point is that Blender is a very good renderer too, so I'm wondering why you would want to 'bypass' Blender if you already got it in Blender in the first place?
Blender's fileformat is all but simple, I did consider it at one point for LDCad as I'm mainly exporting to animate.
I also considered .obj but that one is too simple.
So far POV-Ray is just right for what I wanted to do.
(2018-03-03, 18:31)Merlijn Wissink Wrote: But my point is that Blender is a very good renderer too, so I'm wondering why you would want to 'bypass' Blender if you already got it in Blender in the first place?
I want a text interface instead of a GUI interface. I'm not sure Blender can handle a model as big as Datsville for instance.
RE: Is POVRay still the most liked LDraw HQ renderer? - Travis Cobbs - 2018-03-04
Pixar's RenderMan is free for non-commercial use.  Wink
RE: Is POVRay still the most liked LDraw HQ renderer? - Michael Horvath - 2018-03-17
I asked on the Yafaray forums:
Normally, you need Blender to convert your model to the format used in the Yafaray's XML files. Afterward, you can feed the XML file into Yafaray and render the scene there. However, it should be possible to export an LDraw model directly into XML if you understand the format.
I have uploaded a small scene here:
http://www.mediafire.com/file/730mugylcmvd4g4/ldr_red_rock_racer_new_leocad_blender_scene_file_20180316.zip
It contains a blend file, a rendered image, and an XML file that can be fed into Yafaray Standalone. The developer I spoke with does not seem to understand that I want to skip and bypass Blender totally, so I'm not sure we can get more help from him.
