Parts Request 15400/15303/15100 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Parts Request 15400/15303/15100 (/thread-14116.html) |
Parts Request 15400/15303/15100 - Roland Dahl - 2014-10-10 I recently built some new star wars models in LDraw. These models have some new parts which are not available so far. Unfortunately this new weapon “spring shooter” seems to be widely used now. So I would highly appreciate to have the following parts: #15400 Spring Shooter 1x4 #15303 Arrow 8M for Spring Shooter #15100 Technic, Pin with Friction Ridges Lengthwise and Pin Hole (used in 75054 AT-AT) Thanks and kind regards Roland Re: Parts Request 15400/15303/15100 - Michael Heidemann - 2014-10-10 Please see the reply's to your other post http://forums.ldraw.org/showthread.php?tid=14115&pid=14115#pid14115 Re: Parts Request 15400/15303/15100 - Philippe Hurbain - 2014-10-10 Yes, I overlooked this post before answering the other... As I said, 15100 is an official part. Shooter and arrow are available in LDD and should be relatively easy to convert/adapt. Re: Parts Request 15400/15303/15100 - Philippe Hurbain - 2014-10-11 I'll do the shooter and arrow, but it will take a bit of time, I want to get one first. Re: Parts Request 15400/15303/15100 - Roland Dahl - 2014-10-11 Thank You !! Re: Parts Request 15400/15303/15100 - Philippe Hurbain - 2014-10-29 Parts are there now http://www.ldraw.org/cgi-bin/ptscan.cgi?q=shooter ![]() Still missing a shortcut with shooter + dart... Now on Parts Tracker too! Re: Parts Request 15400/15303/15100 - Roland Dahl - 2014-11-20 Philippe Hurbain Wrote:Parts are there now http://www.ldraw.org/cgi-bin/ptscan.cgi?q=shooter Wow! Thanks a lot. I will update the "shooter" models soon. Re: Parts Request 15400/15303/15100 - Roland Dahl - 2014-11-21 Philippe Hurbain Wrote:Parts are there now http://www.ldraw.org/cgi-bin/ptscan.cgi?q=shooter Hi Philo, seems there is a tiny coloring bug in 15400, while the complete shooter is fine:
Re: Parts Request 15400/15303/15100 - Philippe Hurbain - 2014-11-21 It doesn't seem to depend on the part itself. What editor/viewer are you using? Sometimes SR3D builder does weird things on shortcuts... Re: Parts Request 15400/15303/15100 - Roland Dahl - 2014-11-21 Philippe Hurbain Wrote:It doesn't seem to depend on the part itself. What editor/viewer are you using? Sometimes SR3D builder does weird things on shortcuts... Yes, that's it: SR3D Opening the same file in LDCad no problem occurs. Well, it's a magical world ...... Re: Parts Request 15400/15303/15100 - Philippe Hurbain - 2014-11-21 I think that SR3D behaves correctly on shortcuts if you first select color then add the part. Problems occur when you try to recolor after placing part. Re: Parts Request 15400/15303/15100 - Merlijn Wissink - 2014-11-21 When using a shortcut part in SR3D, it doesn't add the shortcut part, it adds all the parts in the shortcut. Personally, I find that quite annoying, because when opening it in another editor or software (such as lpub), you end up with all the loose parts... I don't know if it's approapiate here, but you can select subparts in a shortcut part by holding shift and selecting a piece in the shortcut. |
