End with a... ? - Printable Version
+--- Thread: End with a... ? (/thread-14010.html)
End with a... ? - Stephen - 2014-09-26
Quote from: http://www.ldraw.org/article/218.html
Quote:Line Termination
All lines in the file must use the standard DOS/Windows line termination of(carriage return/line feed). The file is permitted (but not required) to end with a. It is recommended that all LDraw-compliant programs also be capable of reading files with the standard Unix line termination of(line feed).
End with a what? I'm assuming what's missing is "carriage return/line feed" ?
Re: End with a... ? - Michael Heidemann - 2014-09-26
Yes Smile
Re: End with a... ? - Tim Gould - 2014-09-26
Should that be a "0" (zero)?
NO!
Re: End with a... ? - Travis Cobbs - 2014-09-26
0 is certainly valid as the last byte of an LDraw file (right after an <LF>). I suspect that this is supposed to say that the last line may or may not have a <CR><LF> at the end, but I can't remember.
Re: End with a... ? - Steffen - 2014-09-27
The sentence
Quote:The file is permitted (but not required) to end with a.
should read instead
Quote:Terminating the last line of a file with it is optional.
Re: End with a... ? - Willy Tschager - 2014-09-27
http://forums.ldraw.org/showthread.php?tid=4401&pid=4401#pid4401
Re: End with a... ? - Michael Heidemann - 2014-09-27
Yes, that is exactly what we discussed that time.
Thanks - that makes it really clear Smile
Re: End with a... ? - Willy Tschager - 2014-10-11
I finally found the time to correct this. Thanks for pointing out. Let me know if there are more hiccups caused by the transition from PN.
Re: End with a... ? - Steffen - 2014-10-11
thank you for the correction.
