Recent Messages - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Administrative (https://forums.ldraw.org/forum-4.html) +--- Forum: Website Suggestions/Requests/Discussion (https://forums.ldraw.org/forum-23.html) +--- Thread: Recent Messages (/thread-13637.html) |
Recent Messages - Orion Pobursky - 2014-08-09 Recent Messages is broken for me. Can anyone confirm? Re: Recent Messages - Magnus Forsberg - 2014-08-09 Yes it is. It's been gone since this morning. Re: Recent Messages - Philippe Hurbain - 2014-08-09 Was going to report the issue... Same thing here! Re: Recent Messages - Michael Heidemann - 2014-08-09 It is still broken. Re: Recent Messages - Orion Pobursky - 2014-08-09 Ok. Investigating. Since I didn't change anything, I suspect that something changed on the server so it may take me a bit to sort it out. Re: Recent Messages - Orion Pobursky - 2014-08-11 Ok problem solved but now avatars aren't working. Odd. Re: Recent Messages - Orion Pobursky - 2014-08-11 So the problem seems to stem from the interaction between php, mySQL, and ImageMagick. I'm still investigating but it may take some time. Re: Recent Messages - Orion Pobursky - 2014-08-11 Broken images were on my end. Please clear your browser cache if this problem exists for you. If the problem still exists after the cage clear, please let me know. Re: Recent Messages - Philippe Hurbain - 2014-08-11 Seems to be running fine now! Thanks, Orion! Re: Recent Messages - Michael Heidemann - 2014-08-11 I confirm that it is working again - thanks Orion
Re: Recent Messages - Magnus Forsberg - 2014-08-11 It works for me too, but I think I've found another issue. Didn't added pictures use to be clickable before? If I remember correctly they were added, in the text, in a smaller size, and when I clicked on it, it was opened in a new tab. Now, all pictures are added in the text in full size. Re: Recent Messages - Orion Pobursky - 2014-08-12 I had to turn off that extension. It was partially to blame. I think my host upgraded the image processing software and it was causing php errors. |
