parts beginning with "u" - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: parts beginning with "u" (/thread-13413.html) |
parts beginning with "u" - Michael Horvath - 2014-07-09 Is there any way to rename the parts starting with the letter "u"? They make it frustrating to select a sub-model in MLCad's Add Part dialog when sorting the list by name, because you have to sort through all the "u"s. Thanks. Re: parts beginning with "u" - Tim Gould - 2014-07-10 LDMakeList allows you to exclude the first characted when making Parts.lst Run as Code: LDMakeList -IuURe: parts beginning with "u" - Michael Horvath - 2014-07-10 Where can I find LDMakeList? I did a quick search of my computer but couldn't find it. Re: parts beginning with "u" - Willy Tschager - 2014-07-10 In case you've installed using the AIOI it is in your LDraw root folder. The AIOI 2014-01 will also include Mike's GUI: http://forums.ldraw.org/showthread.php?tid=12417&pid=12417#pid12417 w. |
