 L3P Add-On u-parts problems - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: LDraw Programs (https://forums.ldraw.org/forum-7.html) +--- Forum: LDraw File Processing and Conversion (https://forums.ldraw.org/forum-22.html) +--- Thread: L3P Add-On u-parts problems (/thread-12994.html)  |
L3P Add-On u-parts problems - Damien Roux - 2014-05-06 Hi there, As I'm used to model my own LGEO parts for my renders, I frequently add new parts to the lg_elements.lst provided with L3P Add-On. Then, it will recognize the new part as a LGEO-available one, and will make me a pov file using this LGEO equivalent part. Problem is that u-parts (u1125 as an example) seems not te be taken into account when inserted in lg_elements.lst. Does someone has an idea of how can I proceed to make L3P Add-On take those parts into account if inserted in the lg_elements.lst? I'm not even sure that the problem is the name (beginning by "u") but usually it work like a charm with standard 4 digits part name). Re: L3P Add-On u-parts problems - Damien Roux - 2014-05-10 As nobody answered. ![]() I've managed to tweak Ldview's Pov-ray export to take those parts into account. So, Problem more or less solve. Re: L3P Add-On u-parts problems - Travis Cobbs - 2014-05-11 If you'd ask about LDView's POV export, I would have helped you out, but I try not to discourage people from using L3P, since Lars gave me a lot of help in my development of POV export in LDView.  |
