How to use helper parts in MLCad v3.4 - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: General LDraw.org Discussion (https://forums.ldraw.org/forum-6.html) +--- Thread: How to use helper parts in MLCad v3.4 (/thread-12548.html) |
How to use helper parts in MLCad v3.4 - Zhengrong Zang - 2014-02-22 I want to use those helper parts (http://www.holly-wood.it/ldraw/helper-en.html) on MLCad v3.4, but I don't know how to install them because that article was based on o,design MLCad, what can I do? Re: How to use helper parts in MLCad v3.4 - Max Martin Richter - 2014-02-22 The best way is to put them in an addition folder "helpers" in your "unofficial" folder. (<LDRAW Base directory>\Unofficial\Helper). Then open you MLCad.ini (this is stored in your MLCad folder). Some lines before the very end of this file, you will find a section [SCAN_ORDER] Just add a line with a new number: Code: X = SHOW <LDRAWDIR>Unofficial\HelpersRestart MLCad. Maybe you have to set up your parts tree, that it shows the helper. (I'm not sure about this) /Max Re: How to use helper parts in MLCad v3.4 - Zhengrong Zang - 2014-02-22 Max Martin Richter Wrote:The best way is to put them in an addition folder "helpers" in your "unofficial" folder.It is said there ice no Unofficlal folder in LDraw folder..., and even if I copy all filets tomamfolder inside ldraw/parts, no items shown in helperrts tree .. Re: How to use helper parts in MLCad v3.4 - Willy Tschager - 2014-02-22 Read: http://www.holly-wood.it/mlcad/customizing-en.html w. Re: How to use helper parts in MLCad v3.4 - Zhengrong Zang - 2014-02-22 Willy Tschager Wrote:Read:It seems look not work...did you try it by yourself? Re: How to use helper parts in MLCad v3.4 - Michael Heidemann - 2014-02-22 At least here this works. My Scan Order section looks like: [SCAN_ORDER] 1 = HIDE <LDRAWDIR>P 2 = HIDE <LDRAWDIR>plasticant\p 3 = SHOW <LDRAWDIR>Parts 4 = SHOW <LDRAWDIR>Unofficial\parts 5 = SHOW <LDRAWDIR>plasticant\parts Please send yours, so we can see what might get wrong. Re: How to use helper parts in MLCad v3.4 - Zhengrong Zang - 2014-02-24 Michael Heidemann Wrote:At least here this works.Thanks a lot, I got it. |
