Parts we are Working on - Part Drei - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Part Requests (https://forums.ldraw.org/forum-30.html) +--- Thread: Parts we are Working on - Part Drei (/thread-26656.html) |
RE: Parts we are Working on - Part Drei - Jeff Jones - 2025-04-23 changed lbg to dbg think the black lines on belt too thin and the black outlines on the gold thing needs rounded corners RE: Parts we are Working on - Part Drei - Chris Böhnke - 2025-04-23 Hard to tell - would be easier if you uploaded directly to the Parts Tracker
RE: Parts we are Working on - Part Drei - Willy Tschager - 2025-04-24 (2025-04-23, 14:16)Jeff Jones Wrote: 3rd part made in ldpc BL or RB ref? w. RE: Parts we are Working on - Part Drei - Jeff Jones - 2025-04-28
RE: Parts we are Working on - Part Drei - Jeff Jones - 2025-05-19 hola since ldd mesh is off i redid some of the parts to be more accruate since i dont own part i based it off images is it accruate? RE: Parts we are Working on - Part Drei - Chris Böhnke - 2025-05-19 What exactly is off with the LDD mesh for the Kranxx/Rench Head? RE: Parts we are Working on - Part Drei - Jeff Jones - 2025-05-19 (2025-05-19, 10:38)Chris Böhnke Wrote: What exactly is off with the LDD mesh for the Kranxx/Rench Head? the "brow" on the forehead its pronunced on the ldd mesh but smooth on the actual part according to the images
also the eyebrows are a bit smaller on the ldd mesh also heres the dats i did, tbh a bit rushed
85948s01.dat (Size: 115.45 KB / Downloads: 6)
er6t.dat (Size: 462 bytes / Downloads: 5)
RE: Parts we are Working on - Part Drei - Jeff Jones - 2025-07-12 good enough? RE: Parts we are Working on - Part Drei - Jeff Jones - 2025-07-16 ldd mesh is inaccruate no stud sized thing on neck, seems arm bar should longer neck bar shorter any messaurment? RE: Parts we are Working on - Part Drei - Jeff Jones - 2026-03-15 only thing missing are the squares on the side cant find a good ref for that |
