Discussion - proposal to extend !TEXMAP specification - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: General (https://forums.ldraw.org/forum-12.html) +--- Forum: Official File Specifications/Standards (https://forums.ldraw.org/forum-32.html) +--- Thread: Discussion - proposal to extend !TEXMAP specification (/thread-29327.html) Pages:
1
2
RE: Discussion - proposal to extend !TEXMAP specification - N. W. Perry - 2026-02-20 (2026-02-19, 16:51)Max Murtazin Wrote: In short, when you use anything non-raster as a texture, you gotta rasterize it at some step, and that step would most likely be before supplying it to the renderer, and, as such, you just won't be able to do properly scale resolution. While you *can* write a custom renderer that would rasterize the texture at "render-time", most people simply won't, as it's hard, requires custom approach (so not supported natively by stuff like OpenGL) and not best performance-wise (which is important for real-time renderers) That's pretty much as I'd expect, though I should emphasize nothing in the proposed specification should preclude someone from writing such a renderer if they felt motivated to do so. Roland's proposed implementation may have inspired my interest in this topic, but it's not the only possible implementation, so the proposed extension to TEXMAP should be seen as enabling, but separate from, that specific implementation. On the subject of resolution, it's my understanding that with a mip mapping approach, you start with a "master" resolution and downsample from there, so you don't lose performance or degrade the visual at lower zoom levels. Conversely, if the master resolution is set high enough—and this would be user-configurable, not set by the spec—you could certainly get acceptable render quality up to a very respectable zoom level. RE: Discussion - proposal to extend !TEXMAP specification - Travis Cobbs - 2026-02-20 (2026-02-19, 18:23)Roland Melkert Wrote: True, but the main advantage (imho) is it doesn't have to be a 'normal' texture. You could eg store material parameters (per texture pixel) instead of rgb values. I will add that in theory a program could also scale the size of the generated textures based on how many are present in the model and the characteristics of the machine being run on (in addition to how big the geometry is in LDraw units). Regarding using LDU as a hint for size, that does presuppose that the LDraw geometry is done at a scale that matches the projected area for the texture. There's no particular reason for this to be the case, and one texture can even be used at multiple scales. However, it should probably be recommended that the LDraw geometry in the pseudo-texture match the scale it's being projected at. RE: Discussion - proposal to extend !TEXMAP specification - Philippe Hurbain - 2026-02-26 This definitely looks like that using a LDraw file as a source image ia a good idea, as it solves several shortcomings of current implementations (eg. render of metallic paints). ...and a related idea: the LDraw pattern used as image does not need to be flat. Not only it can be layered, simplifying the drawing process (as already tested by Roland), but also formed! I think that we could very easily "convert" many existing 3D patterns (eg. the minifig heads) to use the new specification. Legacy renderers would still used current formed pattern as fallback, the new ones would apply the existing pattern onto the raw shape, eliminating the crumbled pattern effect and allowing for clean primitive substitution... RE: Discussion - proposal to extend !TEXMAP specification - Roland Melkert - 2026-02-27 First test result: Source mpd attached. This projects the ldr given in !TEXMAP onto a tight fitting 1280x1280 texture. And then use it like any normal TEXMAP texture. The final version has to do (Way) more with dimensions and positioning, but I was thinking this is a nice little proof of concept already? RE: Discussion - proposal to extend !TEXMAP specification - Magnus Forsberg - 2026-02-28 (2026-02-27, 22:40)Roland Melkert Wrote: First test result: Doesn't work for me. What am I missing? RE: Discussion - proposal to extend !TEXMAP specification - N. W. Perry - 2026-02-28 (2026-02-28, 13:28)Magnus Forsberg Wrote: Doesn't work for me. What am I missing? Roland's special test build of LDCad. ![]() What you should be able to see are the unpatterned head (which shows up white for some reason in LDView…?) and the pattern file itself, which consists of two layers, one for each color. RE: Discussion - proposal to extend !TEXMAP specification - Nils Schmidt - 2026-02-28 (2026-02-27, 22:40)Roland Melkert Wrote: This projects the ldr given in !TEXMAP onto a tight fitting 1280x1280 texture. And then use it like any normal TEXMAP texture. Thank you for sharing this proof of concept file. I am excited to see how this will evolve. RE: Discussion - proposal to extend !TEXMAP specification - Hageta - 2026-02-28 (2026-02-27, 22:40)Roland Melkert Wrote: First test result:I edited the file a bit to see how its structured: The red quad visualises the input parameters of the texmap command. I like how layers are implemented in this example. In this examples the coordinates of the pattern match the coordinates of the part, how would you reuse a pattern on a different part. Should the texmap command include transformation parameters for the pattern? This is the modified file:
ldrTexTest.ldr (Size: 9.99 KB / Downloads: 1)
RE: Discussion - proposal to extend !TEXMAP specification - N. W. Perry - 2026-02-28 As a first test result I'd say it's already quite promising. I'd be curious to see the difference from a cylindrical projection (I assume the result is no different than the current method). On the question of resolution, as far as I can tell this comes out no worse than the maximum available in LDCad, which I think is as it should be. RE: Discussion - proposal to extend !TEXMAP specification - Roland Melkert - 2026-02-28 (2026-02-28, 16:56)Hageta Wrote: I like how layers are implemented in this example. In this examples the coordinates of the pattern match the coordinates of the part, how would you reuse a pattern on a different part. Should the texmap command include transformation parameters for the pattern?I got the 1/2 face pattern from Chris, only removed the yellow filling. Fun thing about 2d projection is you don't have to worry about overlap so if you need some black text on a white background you would only need to add a white quad and the text itself for it to work as a texture. As for reusing the pattern there are no real limitations. Although there are some things that will make it harder to implement. Like using color16 inside the texture pattern, a renderer would need a special shader or prepare a separate texture for each color usage. (2026-02-28, 16:56)N. W. Perry Wrote: As a first test result I'd say it's already quite promising. I'd be curious to see the difference from a cylindrical projection (I assume the result is no different than the current method).I since replaced the hardcoded 1280x1280 with a resolution of 50 times the source's ldu width/height which in this case end up as 1200x950 RE: Discussion - proposal to extend !TEXMAP specification - N. W. Perry - 2026-03-01 (2026-02-28, 21:04)Roland Melkert Wrote: As for reusing the pattern there are no real limitations. Although there are some things that will make it harder to implement. Couldn't color 16 be assigned as a parameter in the TEXMAP meta? (Or is that an example of "harder to implement"?) For that matter, couldn't there be parameters to map any color to any other color (given, for example, as pairs of numbers for each source/destination color in the texture)? |
