New parts from Lego Instructions app - Printable Version +- LDraw.org Discussion Forums (https://forums.ldraw.org) +-- Forum: Models and Parts (https://forums.ldraw.org/forum-18.html) +--- Forum: Parts Authoring (https://forums.ldraw.org/forum-19.html) +--- Thread: New parts from Lego Instructions app (/thread-27738.html) |
RE: New parts from Lego Instructions app - Jeff Jones - 2024-12-02 i have aton of BI exports would take a while for me to organize all RE: New parts from Lego Instructions app - Jeff Jones - 2024-12-02 heres some of the parts i have.
105177RE: New parts from Lego Instructions app - Lewis - 2025-01-08 Any chance we can get parts 1879 and 5784? They are both on set 76781 on the instructions app. RE: New parts from Lego Instructions app - Jeff Jones - 2025-01-09 if you wanna add the 2x2 studs on the back of the hulk torso add these 1 16 50 -142.929642 34.570362 1 0 0 0 0.707107 0.707107 0 -0.707107 0.707107 stug2-2x2.dat RE: New parts from Lego Instructions app - Jeff Jones - 2025-01-30 some toy story parts ![]() rex assembly (89895 + 89898 + 89899 + 89891 (89890 + 89896))RE: New parts from Lego Instructions app - Stephan den Ridder - 2025-01-31 I am actually working through the LEGO API to find parts. I already did 100,000 through 999,999. Now working on 1,000 through 99,999. After that I'll do 1,000,000 and upwards where all shaped parts (sails etc.) and assembly subparts are located. I asked ChatGPT to create a Python script that checks which numbers have a file associated with them, and which are empty. RE: New parts from Lego Instructions app - Chris Böhnke - 2025-02-01 (2025-01-31, 13:42)Stephan den Ridder Wrote: I am actually working through the LEGO API to find parts. I already did 100,000 through 999,999. Now working on 1,000 through 99,999. After that I'll do 1,000,000 and upwards where all shaped parts (sails etc.) and assembly subparts are located. I asked ChatGPT to create a Python script that checks which numbers have a file associated with them, and which are empty. Does that mean it is possible to access all available parts on Lego's server directly? Are these numbers what Lego calls "Design ID"? RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-01 (2025-02-01, 17:16)Chris Böhnke Wrote: Does that mean it is possible to access all available parts on Lego's server directly? almost all yup RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-01 found cull obsidian's head + armor part wonder if the same could be said for dogshank. RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-02 made a shoddy recreation of the cull obsidian assembly using the maui piece as the base the vertices dont match up as seen in the pictures.
Annotation 2025-02-02 140608.png (Size: 72.78 KB / Downloads: 944)
RE: New parts from Lego Instructions app - Stephan den Ridder - 2025-02-03 (2025-02-01, 17:16)Chris Böhnke Wrote: Does that mean it is possible to access all available parts on Lego's server directly?The trick in some cases is to know what the designID is. Especially over-moulded parts have unlogical designIDs. Or parts that are part of an assembly. RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-03 anyone here have peach's torso piece i have the arm, dress and battery cover piece RE: New parts from Lego Instructions app - Gerald Lasser - 2025-02-03 (2025-02-03, 13:39)Jeff Jones Wrote: anyone here have peach's torso piece i have the arm, dress and battery cover piece All SM Stuff is in the SM-App RE: New parts from Lego Instructions app - Javier Orquera - 2025-02-03 (2025-02-03, 13:39)Jeff Jones Wrote: anyone here have peach's torso piece i have the arm, dress and battery cover piece Here it is the full Peach including Cat Suit. Unfortunately, I'm too lasy to convert the meshes, sorry, and it's in .fbx format. RE: New parts from Lego Instructions app - Magnus Forsberg - 2025-02-03 (2025-02-03, 20:27)Javier Orquera Wrote: Here it is the full Peach including Cat Suit. Unfortunately, I'm too lasy to convert the meshes, sorry, and it's in .fbx format. That zip-file seems corrupt. Can't open it. RE: New parts from Lego Instructions app - Javier Orquera - 2025-02-03 (2025-02-03, 22:37)Magnus Forsberg Wrote: That zip-file seems corrupt. Can't open it. I dowloaded it on my phone and I'm able to open it. Try again. RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-04 (2025-02-03, 22:37)Magnus Forsberg Wrote: That zip-file seems corrupt. Can't open it. rename it to .rar and it works RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-04 what???? RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-05 HERE BOTTOM STUDS 1 330 40 -5.25 0 -1 0 0 0 -1.25 0 0 0 1 stug4-1x3.dat 1 330 0 -5.25 -20 -1 0 0 0 -1.25 0 0 0 1 stug4-1x3.dat 1 330 -20 -5.25 0 -1 0 0 0 -1.25 0 0 0 1 stud4.dat 1 330 0 -5.25 20 -1 0 0 0 -1.25 0 0 0 1 stug4-1x3.dat
66953 (is in a zip due to subfiles being in a different origin)
RE: New parts from Lego Instructions app - Chris Böhnke - 2025-02-05 Was the Jabba pre-polished or why does it have cond-lines? At first glance this looks almost PT ready, not something I'm used to from Lego imports. EDIT: Ok the bottom studs are missing ![]() Probably a bit more. But it still looks surprisingly polished. RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-05 (2025-02-05, 20:55)Chris Böhnke Wrote: Was the Jabba pre-polished or why does it have cond-lines? the raw mesh has condlines only polishing done was combining the 2 lower part meshes into one and renaming the filenames RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-06 🤫🧏 RE: New parts from Lego Instructions app - Gerald Lasser - 2025-02-20 (2025-01-30, 13:27)Jeff Jones Wrote: some toy story parts I am preparing Ham RE: New parts from Lego Instructions app - Jeff Jones - 2025-02-20 (2025-02-20, 12:02)Gerald Lasser Wrote: I am preparing Ham Nice
RE: New parts from Lego Instructions app - Magnus Forsberg - 2025-02-20 (2025-02-20, 12:02)Gerald Lasser Wrote: I am preparing Ham Air dried, or smoking it?
RE: New parts from Lego Instructions app - Gerald Lasser - 2025-02-21 (2025-02-20, 21:22)Magnus Forsberg Wrote: Air dried, or smoking it? Gonna slice it! RE: New parts from Lego Instructions app - Jeff Jones - 2025-04-11 anyone know what ids the dewback jaw (18134) and quantam suit hulk (66639) have in bi they have renders in brickowl which to me means its in bi but nothing shows up also honorable mention are dewback body (18131) and normal hulk (68137) they dont have renders in brickowl but are in the time range to be available in bi
RE: New parts from Lego Instructions app - Philippe Hurbain - 2025-04-11 (2025-04-11, 10:58)Jeff Jones Wrote: they have renders in brickowl which to me means its in bi but nothing shows upAll that it means is that LEGO does have a digital model (not really surprising ). Brickset, which uses LEGO image, uses the same render as Brickowl...
RE: New parts from Lego Instructions app - Gerald Lasser - 2025-04-11 (2025-04-11, 10:58)Jeff Jones Wrote: anyone know what ids the dewback jaw (18134) and quantam suit hulk (66639) have in bi Is this the guy, 66639? Edit: This might be the normal Hulk... RE: New parts from Lego Instructions app - Gerald Lasser - 2025-04-11 This looks more like 66639 RE: New parts from Lego Instructions app - Gerald Lasser - 2025-04-11 (2025-04-11, 10:58)Jeff Jones Wrote: anyone know what ids the dewback jaw (18134) and quantam suit hulk (66639) have in bi Dewback, is it this you are looking for? RE: New parts from Lego Instructions app - Jeff Jones - 2025-04-11 looks like gerald forgot something. RE: New parts from Lego Instructions app - Timothy Hall - 2025-09-16 I have a question for Vincent, or anyone else who may know. What is the best asset viewer/export tool to use with the mesh assets? Right now, I am using AssetStudioGUI for Windows and for some meshes that are multiple colors it exports all the meshes separately. Is there an asset viewer that will export them combined? Thanks! RE: New parts from Lego Instructions app - Javier Orquera - 2025-09-16 (2025-09-16, 4:13)Timothy Hall Wrote: I have a question for Vincent, or anyone else who may know. What is the best asset viewer/export tool to use with the mesh assets? Right now, I am using AssetStudioGUI for Windows and for some meshes that are multiple colors it exports all the meshes separately. Is there an asset viewer that will export them combined? Hello: in AssetStudio you have a menu called Model; in there, there is several options to export, one of them is "Export selected objects (merge)". Hope it help you. RE: New parts from Lego Instructions app - Timothy Hall - 2025-09-17 (2025-09-16, 14:17)Javier Orquera Wrote: Hello: in AssetStudio you have a menu called Model; in there, there is several options to export, one of them is "Export selected objects (merge)". Hope it help you. I have tried that. In this example I select 4 meshes (they are highlighted in blue) and when I choose export selected objects (merge) I get an error saying no object selected for export. Any ideas? Thanks! RE: New parts from Lego Instructions app - Timothy Hall - 2025-09-17 (2025-09-17, 1:35)Timothy Hall Wrote: I have tried that. In this example I select 4 meshes (they are highlighted in blue) and when I choose export selected objects (merge) I get an error saying no object selected for export. Hello again. I finally figured it out. Thanks for trying to help me.
RE: New parts from Lego Instructions app - Lisa Winter - 2025-12-06 (2023-09-29, 21:19)Vincent Messenet Wrote: Now these hairs exist in a solid color, while the others are transparent with two colors. In your opinion, how should these multicolored ones be modeled: groups of triangles or individual triangles with different colors? ![]() ![]() ![]() Kind regards, Lisa [/quote] RE: New parts from Lego Instructions app - Philippe Hurbain - 2025-12-07 As the black only version is used in Star Trek, I was considering modeling it, but... solving the trans/opaque multicolor marbled versions gives me a headache ![]() Maybe something like this? https://library.ldraw.org/parts/1443 But - the opaque section in trans/opaque version would theoretically need an internal separation, and texmap doesn't work well with trans/opaque mix. Actually I was considering doing a plain version with a "needs work" notice! RE: New parts from Lego Instructions app - Lisa Winter - 2025-12-07 (2025-12-07, 8:44)Philippe Hurbain Wrote: As the black only version is used in Star Trek, I was considering modeling it, but... solving the trans/opaque multicolor marbled versions gives me a headache Please let me know if you want to convert it, so I stop and go look for another brick. Kind regards, Lisa RE: New parts from Lego Instructions app - Philippe Hurbain - 2025-12-07 (2025-12-07, 13:40)Lisa Winter Wrote: Please let me know if you want to convert it, so I stop and go look for another brick.please go on
RE: New parts from Lego Instructions app - Vincent Messenet - 2026-04-05 Could someone please clean 3320 for PT? RE: New parts from Lego Instructions app - Gerald Lasser - 2026-04-06 (2026-04-05, 21:35)Vincent Messenet Wrote: Could someone please clean 3320 for PT? only the printed one is missing all others done RE: New parts from Lego Instructions app - Vincent Messenet - 2026-04-06 (2026-04-06, 19:18)Gerald Lasser Wrote: only the printed one is missing Many thanks Gerald! RE: New parts from Lego Instructions app - Willy Tschager - 2026-07-17 37496 - Motorcycle Chassis, Snowmobile needs a fix: https://library.ldraw.org/parts/24787 it is listed on Digital-Bricks as a part in Unity but no file is available. Anyone? w. RE: New parts from Lego Instructions app - Javier Orquera - 2026-07-17 (2026-07-17, 13:37)Willy Tschager Wrote: 37496 - Motorcycle Chassis, Snowmobile needs a fix: Here it is the raw part (need a better scale). RE: New parts from Lego Instructions app - Magnus Forsberg - 2026-07-17 (2026-07-17, 16:06)Javier Orquera Wrote: Here it is the raw part (need a better scale). The problem isn't the mesh. It's the inadequate clean-up of the current mesh at the PT. Looks like a raw export upload. RE: New parts from Lego Instructions app - Gerald Lasser - 2026-07-17 (2026-07-17, 20:37)Magnus Forsberg Wrote: The problem isn't the mesh. It's the inadequate clean-up of the current mesh at the PT. I am polishing it. What about the origin? Any proper suggestions? RE: New parts from Lego Instructions app - Magnus Forsberg - 2026-07-18 (2026-07-17, 22:08)Gerald Lasser Wrote: I am polishing it. What about the origin? Any proper suggestions? Think it could be moved so that it fits the Faring, 50860 Like the Dirt Bike does in 50860c01 Also think we should make a complete assy shortcut, with ski and track. RE: New parts from Lego Instructions app - Gerald Lasser - 2026-07-18 (2026-07-18, 20:46)Magnus Forsberg Wrote: Think it could be moved so that it fits the Faring, 50860 Yes, a complete assy is helpful RE: New parts from Lego Instructions app - Gerald Lasser - 2026-07-20 I am rotating the 37496 so that it will be standing on a horizontal surface with the ski and the chain attached. the fairing needs to be rotated to fit. |
