As far as I can see we do not have the shape of this part in LDD. So it has to be build in old fashion. This may take a while if someone like to start this task. It is not a very common part!
I've been meaning to do this one, I guess I got an excuse to do that.
Now to find one of these in my part bins...
edit: found one, let's see here..
for fellow parts authors: I got this much done on this part and now am trying to put the base for the curve section:
Right now that's just 4 48/4-8edge.dat's. You guys got any better ideas on how to do this or is this my best bet? Curves like this still get me baffled from time to time.
If possible put this part on your scanner. So you get the curve better i think.
If you use primitive, please be sure to use the same circlepoint for each curve primitive.
This way I have done it on 32218.dat. A lot of try and error, but the result works great
I don't have a scanner so I just use a camera and try to get as perpendicular a picture as possible. It actually works well most of the time but it tends to leave my back hurting. It's also quite time consuming so I thought if there was some faster way to do it. I guess I'll experiment with the circles a bit more and if I can't do it that way, resort to the camera approach..
Indeed, I try first to fit a primitive, but it's not always possible... in that case, I take a photo and use LDPC - or I guess you could use your own LDForge
Try this.
0 test
1 16 0 0 60 0 -1 0 1 0 0 0 0 1 connhole.dat
1 16 0 20 0 -1 0 0 0 -1 0 0 0 1 connhole.dat
0 BFC CERTIFY INVERTNEXT
1 4 10 -55.025 9 0 -20 0 66.025 0 0 0 0 66.025 48\5-48cyli.dat
1 24 10 -55.025 9 0 1 0 66.025 0 0 0 0 66.025 48\5-48edge.dat
1 24 -10 -55.025 9 0 1 0 66.025 0 0 0 0 66.025 48\5-48edge.dat
1 6 10 -55.025 9 0 -8 0 68.661 0 0 0 0 68.661 48\5-48cyli.dat
1 6 -10 -55.025 9 0 8 0 68.661 0 0 0 0 68.661 48\5-48cyli.dat
1 24 10 -55.025 9 0 1 0 68.661 0 0 0 0 68.661 48\5-48edge.dat
1 24 2 -55.025 9 0 1 0 68.661 0 0 0 0 68.661 48\5-48edge.dat
1 24 -2 -55.025 9 0 1 0 68.661 0 0 0 0 68.661 48\5-48edge.dat
1 24 -10 -55.025 9 0 1 0 68.661 0 0 0 0 68.661 48\5-48edge.dat
1 6 10 -55.025 9 0 -8 0 81.389 0 0 0 0 81.389 48\5-48cyli.dat
1 6 -10 -55.025 9 0 8 0 81.389 0 0 0 0 81.389 48\5-48cyli.dat
1 24 10 -55.025 9 0 1 0 81.389 0 0 0 0 81.389 48\5-48edge.dat
1 24 2 -55.025 9 0 1 0 81.389 0 0 0 0 81.389 48\5-48edge.dat
1 24 -2 -55.025 9 0 1 0 81.389 0 0 0 0 81.389 48\5-48edge.dat
1 24 -10 -55.025 9 0 1 0 81.389 0 0 0 0 81.389 48\5-48edge.dat
1 4 10 -55.025 9 0 -20 0 84.025 0 0 0 0 84.025 48\5-48cyli.dat
1 24 10 -55.025 9 0 1 0 84.025 0 0 0 0 84.025 48\5-48edge.dat
1 24 -10 -55.025 9 0 1 0 84.025 0 0 0 0 84.025 48\5-48edge.dat
4 16 10 11 9 10 13.636 9 10 13.0455 17.9603 10 10.4322 17.6163
4 16 10 10.4322 17.6163 10 13.0455 17.9603 10 11.2947 26.7695 10 8.74855 26.0873
4 16 10 8.74855 26.0873 10 11.2947 26.7695 10 8.4109 35.2766 10 5.9755 34.2678
4 16 10 5.9755 34.2678 10 8.4109 35.2766 10 4.43543 43.3305 10 2.15265 42.0125
4 16 10 2.15265 42.0125 10 4.43543 43.3305 10 -0.550932 50.7995 10 -2.64229 49.1947
4 16 -10 10.4322 17.6163 -10 13.0455 17.9603 -10 13.636 9 -10 11 9
4 16 -10 8.74855 26.0873 -10 11.2947 26.7695 -10 13.0455 17.9603 -10 10.4322 17.6163
4 4 -10 5.9755 34.2678 -10 8.4109 35.2766 -10 11.2947 26.7695 -10 8.74855 26.0873
4 16 -10 2.15265 42.0125 -10 4.43543 43.3305 -10 8.4109 35.2766 -10 5.9755 34.2678
4 16 -10 -2.64229 49.1947 -10 -0.550932 50.7995 -10 4.43543 43.3305 -10 2.15265 42.0125
4 16 2 13.0455 17.9603 2 13.636 9 2 26.364 9 2 25.6641 19.6213
4 16 2 11.2947 26.7695 2 13.0455 17.9603 2 25.6641 19.6213 2 23.5886 30.0635
4 16 2 8.4109 35.2766 2 11.2947 26.7695 2 23.5886 30.0635 2 20.1703 40.1476
4 16 2 4.43543 43.3305 2 8.4109 35.2766 2 20.1703 40.1476 2 15.4579 49.6945
4 16 2 -0.549363 50.8008 2 4.43543 43.3305 2 15.4579 49.6945 2 9.54903 58.5496
4 16 -2 25.6641 19.6213 -2 26.364 9 -2 13.636 9 -2 13.0455 17.9603
4 16 -2 23.5886 30.0635 -2 25.6641 19.6213 -2 13.0455 17.9603 -2 11.2947 26.7695
4 4 -2 20.1703 40.1476 -2 23.5886 30.0635 -2 11.2947 26.7695 -2 8.4109 35.2766
4 16 -2 15.4579 49.6945 -2 20.1703 40.1476 -2 8.4109 35.2766 -2 4.43543 43.3305
4 16 -2 9.54903 58.5496 -2 15.4579 49.6945 -2 4.43543 43.3305 -2 -0.549363 50.8008
4 16 10 26.364 9 10 29 9 10 28.2774 19.9653 10 25.6641 19.6213
4 16 10 25.6641 19.6213 10 28.2774 19.9653 10 26.1348 30.7457 10 23.5886 30.0635
4 16 10 23.5886 30.0635 10 26.1348 30.7457 10 22.6057 41.1564 10 20.1703 40.1476
4 16 10 20.1703 40.1476 10 22.6057 41.1564 10 17.7406 51.0125 10 15.4579 49.6945
4 16 10 15.4579 49.6945 10 17.7406 51.0125 10 11.6385 60.1528 10 9.54711 58.5481
1 16 0 11 0 9 0 0 0 1 0 0 0 9 2-4ndis.dat
1 16 0 29 0 -9 0 0 0 -1 0 0 0 9 2-4ndis.dat
4 16 -10 25.6641 19.6213 -10 28.2774 19.9653 -10 29 9 -10 26.364 9
4 16 -10 23.5886 30.0635 -10 26.1348 30.7457 -10 28.2774 19.9653 -10 25.6641 19.6213
4 4 -10 20.1703 40.1476 -10 22.6057 41.1564 -10 26.1348 30.7457 -10 23.5886 30.0635
4 16 -10 15.4579 49.6945 -10 17.7406 51.0125 -10 22.6057 41.1564 -10 20.1703 40.1476
4 16 -10 9.54711 58.5481 -10 11.6385 60.1528 -10 17.7406 51.0125 -10 15.4579 49.6945
4 6 10 -2.64229 49.1947 10 -4.2281 51 -10 -4.2281 51 -10 -2.64229 49.1947
4 5 -10 11.6385 60.1528 -10 8.9193 63.2495 10 8.9193 63.2495 10 11.6385 60.1528
4 4 10 -4.2281 51 10 -20 51 -10 -20 51 -10 -4.2281 51
4 24 -10 -0.550932 50.7995 -10 -0.8837 51.1758 10 -0.8837 51.1758 10 -0.550932 50.7995
4 24 10 9.54711 58.5481 10 9 59.1681 -10 9 59.1681 -10 9.54711 58.5481
4 24 10 9 100 10 9 63.1575 -10 9 63.1575 -10 9 100
