Currently I am working on an update for DATHeader for the following:
BUGFIX: Philo reported that BFC CERTIFY NOCLIP is not detected and corrected.
NEW: The flag for alias files '=' needs to be implemented.
If you know something more that needs to be fixed or should be implemented, please let me know.
I know that also the low res folder is new (p\8\), but as I see this not as a common folder (only used for some special parts at present) I do not put my focus these days on this issue.
I've found that it corrects soft brackets around username, but doesn't tell me about it.
Isn't that a Hold vote?
You'll need to catch "0 BFC INVERTNEXT CLIP" as well as NOCLIP.
and
0 BFC CLIP INVERTNEXT
I do not know if this error should be worth a hold vote, but I feel no, because this error does not prevent the part from being showed correctly.
If I submit a part to the PT I always check with DATHeader and save the file before uploading.
Maybe I'll look what can be done to notify you if you only check a file.
But thank you very much for mention this!
To be more specific, I find the behaviour of DATHeader very strange.
If a file, that has the username in soft brackets, is opened in DATHeader, the brackets have been automagically replaced with hard bracket.
I want to do a review and run a scan for errors. No error is found.
I close the file, of course without saving it.
I then open it in LDDP or a text editor, and the soft brackets are still there.
Strange.
The problem you describes is present. I am currently working on a solution that you will be notified if there are wrong brackets used or not.
I'll keep you updated.
Edit: Version 3.0.12.0 is corrected for this issue.
