Full Version: LDraw All-In-One-Installer 2013-01 now available
Pages: 1 2 3
The LDraw All-In-One-Installer 2013-01, in short AIOI, has been released.
The AIOI supports Windows XP (Home and Pro), Windows Vista (all versions) and Windows 7 (all versions). On 64-Bit Operating Systems it will install in the "Program files (x86)" folder. The Installer will NOT run on Windows 95, 98, ME, NT Ver 4, 2000, or XP below SP2.
Changes:
  • Removed Non-CA Parts Library
  • Unified license pages
  • LDFind 1.3.0.0 added
  • LDMakeList 2.12 added and made it the primer Parts.lst generator
  • Parts.lst is sorted with LDMakeList's -p and -a option, which sorts by description with the patterns at the end of the list and excludes alias files
  • MKList moved to a subfolder as backup
  • Rewrote the search routine for Pov-Ray and added a browse dialog asking for the location of Pov-Ray in case it couldn't be found
There are currently some issues with the registration of a file needed by Sticker Generator when installing on Windows 8.
You can download the AIOI from:
Home > Help > Get Started > LDraw All-In-One-Installer
Many thanks to all the programers who contributed to this release.
Willy Tschager
(LDraw.org Content Manager)
Hi
I have downloaded the LDraw_AIOI_2013-01_setup_32bit_v1.exe installer.
When i try to make a complete install it comes op with 4 file not found errors and one xml file not found.
and it then can't find the pov-ray installer.
it does this on both my win 7 workstation and on my new win 8 workstation.
See the attached .txt (renamed zip) file for screendumps.
When i use LDraw_AIOI_2012-03_setup_32bit_v1.exe on win 7, none of the above errors happens.
But it will not install on win 8 due to an direct x 9 error.
This error does not happen on Win 8.
Can anyone help me with this or is it an error in the installer ??
Kind regards
Knud
Please post the "Setup Log.txt" file in:
C:\Windows\LDraw
Thx, w.
Hi
The file have been attached.
Rename to .zip
Kind Regards
Knud
Many thanks, I'll see that's might wrong. Could you finally posta screenshot of your UAC settings?
Hi
I have attached a .zip file containing a screenshot of my UAC settings and a screenshot of the user i have logged in with.
as you can see the user i have testet with is the admin, so it should not be a security issue.
Kind Regards
Knud
Sticker Generator is written in Visual Basic 6 and is very very old! This would be a good opportunity for someone new to re-write it or create their own better version.
The VB6 source code is still on my website for anyone wanting a headstart:
http://www.scottwardlaw.com/Sticker_Generator/
Scott
Hi Willy
Have you found out what goes wrong with my installation ?
Kind Regards
Knud
No, since I rewrote the entire POVRAY module and made extensive changes throughout the script between 2012-03 and 2013-01 things are quite nasty + I have limited time right now. I'll post here if I've got something ready to test.
Ok, thanks.
Pages: 1 2 3
