In the last few days i've been toying with an idea for an Lpub like program to generate and paginate instructions.
The problem with these kind of programs is that all code to layout stuff is tedious and bug prone (all calculations on margin and alignement and relative positioning and stuff).
The idea is to use something that already does this job and i thought, why not HTML+CSS?
We can put all rendering images into div boxes, giving each box his css class like "assembly", "part list", "step num" etc, and building the appropriate CSS to handle positioning. CSS has plenty of options for this. CSS could be used also for font size, face and placement. One could customize his own CSSs and reuse them (instead of reentering his setup for each file as in LPub).
The generated html+css+images could be used by itself, or better with an integrated renderer we could generate png images just like LPub. It could also be postprocessed with any WYSIWYG html editor.
CSS has some advanced rules to
control pagination.
Rendering of images could of course be handed off to LDView or another renderer just like LPub does.
What do you think ?
I think it's a great idea in principle. And I say 'in principle' because CSS implementations often only follow the rules 'in principle' so I suspect that you will save little or no work in dealing with pagination and all that. But I'd be happy to give it a go if you get it up and running.
You might want to talk to Remi Gagne (or at least look at his code) who has already done a lot of work on
GUI instruction generation in Lic.
Lic does a fine job but is too much automatized. I found it hard to tweak the pages I like them and turned back to LPub.
Basically you could try your idea as LPUB produces all the images you need. Take a small model and do the HTML/CSS for it.
I am also toying around with thoughts on LPUB and making it better, see my post a few days ago.
I agree with you that at first LPUB is strange. But then you can tweak it, if you do the process step by step you end up with a clean file. You can keep your standard settings for assembly/steps/fonts etc and copy it into every LPUB doc you do.
LPUB tends to mix up the META commands it adds to the file, but once you know how it is parsing you can remove additional lines. Especially with some positioning changes, LPUB is not always cleaning up the original setting. Leaving fragments of meta-commands in effectively voiding your change. This need to be changed manually. I think a small cleanup routing to keep steps /call-outs tidy would do wonders!
I would nevertheless love to see how an alternative would do the job.
Gerald
Gerald Lasser Wrote:Basically you could try your idea as LPUB produces all the images you need. Take a small model and do the HTML/CSS for it.
Yeah i did exacly that, here are the results.. They where just hacked quickly and there's much room for improvements:
Demo with table
Demo with div
As i said, it would be relatively trivial for a program to generate the HTML portion, while the css would be hand crafted once.
About LPub, i've been using it a lot, it's great, but all its limitations are starting to annoy me. I think the bug you report is quite serious imho. Having to manually clean old lines is bad, and you have first to understand which ones are the old lines.. And there are other bugs.. I'll probably keep using it but it's far from optimal
Btw are you the developer of LPub ?
No, I am not. The developer of LPub is Kevin Clague.
I wish I could code a bit more to do some patches myself. I am looking into the code of LPub to learn, but that is still a long way to go.
Gerald
Stai ancora lavorando su questo?
Willy Tschager Wrote:Stai ancora lavorando su questo?
No sorry, it was just an experiment.. if you want to develop it, go ahead
parli italiano tu ?
Nicola Wrote:No sorry, it was just an experiment.. if you want to develop it, go ahead
Peccato, ci servirebbe un nuovo generatore d'istruzioni - o almeno qualcuno che ha tempo a disposizione ad aggiustare l'attuale!
Nicola Wrote:parli italiano tu ?
No, what makes you think of this?
Willy, if you would have your wish to become true it would be better to use english language, as I suppose that not all people will use a translator to understand italian language
It looks pretty good so far, something it's missing (as far as I can tell!) is a page notion (html is pretty unreliable for printing/PDFing).
Quote:Ideally in my mind there should be a GUI which hides the innard css with some "presets" functions (like general aligns, positions etc) while still letting you change the css manually for fine tuning.
A philosophy that suits me...
...I like the Friends in space model
Doesn't look that bad. Just as an input I would say that a good BI generator distinguishes itself from the rest in how cleaver it handles subfiles and their inclusion in the main model - apart from the GUI.
Also like the friends in space, my 5 year old would point out that there isn't enough PINK, PINK, PINK! :-D
Philippe Hurbain Wrote:It looks pretty good so far, something it's missing (as far as I can tell!) is a page notion (html is pretty unreliable for printing/PDFing).
Yes pagination is not included. The program should in theory output the images directly (beside the html), eventually using html pagination.
Willy Tschager Wrote:Doesn't look that bad. Just as an input I would say that a good BI generator distinguishes itself from the rest in how cleaver it handles subfiles and their inclusion in the main model - apart from the GUI.
Indeed i have some troubles in deciding what exacly a BI generator should do. Or the degree of freedom left to the user. How do you think it should handle the subfiles?
Thanks for the model, i made it for a competition on Rebrick but didn't win
i'd loved to use more "friends colors" but hadn't the right parts
I like this project, I can see it being very useful and fun.
