A friend who uses Bricksmith sent me a mpd, that I returned him after some changes using MLCad. After that, Bricksmith complained that "submodels are not available". A check of MPD before and after my changes, showed that there was a capitalization issue.
Here is the header of one submodel:
0 FILE righttrack.ldr
0 Right track assembly
0 Name: RightTrack.ldr
Bricksmith refers to this submodel as
1 495 -480 104 59 -1 0 0 0 1 0 0 0 -1 RightTrack.ldr
but it seems that MLCad uses only file field as reference, and silently changes this line to
1 495 -480 104 59 -1 0 0 0 1 0 0 0 -1 righttrack.ldr
...and now Bricksmith is lost!
Any solution?
Could you post the entire file which is causing problems? I can't reproduce this issue as described, and the MPD lookup code has been case-insensitive since Bricksmith 1.0 in 2005.
I think MLCad does it the right way.
But in the end Bricksmith should still be able to find the submodel, cause references should be handled case insensitive (even on a *nix fs). This is needed because loads of official parts use wrong casing in type 1 lines.
Just my 2cts
Well... the entire file is still kind of confidential (EV3 stuff). I'll see with my friend if we can reproduce the problem on a vanilla file
I do not have Bricksmith here, but I can reproduce the change of the type 1 line.
Test_Start.mpd is build like Philo stated.
Test_End.mpd is the saved version after i changed the color.
Maybe this little example helps to verify what happened.
I also tried without changing anything, but only save under a new name and the same result.
MLCad (version 3.40) uses the entry from the '0 FILE' line for the reference. That is good IMHO. We had several discussions about the '0 Name:' entry and the result was in any case that nothing should depend on that entry!
I agree on both points above points. The 0 FILE line contains the official filename. So all lower case is the official filename. And MPD file lookup probably shouldn't be case-sensitive, because no other filename lookups in LDraw files are case-sensitive.
The race to advocate correct behavior is a bit premature, considering Bricksmith already does what is being advocated. This file opens with no errors:
1 4 0 0 0 1 0 0 0 1 0 -0 0 1 3001.dat
0 NOFILE
0 FILE test.ldr
0 NOFILE
As I said, Bricksmith's submodel lookup has been case-insensitive for the entire length of the software's existence. Obviously there's something else going on here. Without seeing the file itself, I don't know what that might be.
