2013-04-20, 20:50
I would like to share a browser based renderer that I have been working on and would like the input of people on how to deploy it.
I am most concerned about copyright issues. The way it is setup right now is that you can only view 5-6 files that I have found on the net (and dont have copyright :-)
First download this simple text file http://www.virtuality.gr/AGG/EaZD-Lego/lego.scene that contains the scene description in XML format and http://www.virtuality.gr/AGG/EaZD-Lego/scene.xml which describes the options you can have in a scene file.
Then visit http://www.virtuality.gr/AGG/EaZD-Lego/index.html and drag the lego.scene file in the rectangle, wait a little (my server is not very fast) and you will see the rendering of the model.
I have tested both Firefox 20.0 and Chrome 26.0. Chrome needs the command line option --allow-file-access-from-files before it starts. In my tests I have found Chrome to be about 20% faster than Firexox.
You can uncomment and view any of the models in the scene file. In XML this '<!--' opens a comment and this '-->' closes one.
The reason you can only see these examples is because I also have them on my server. But as you can put your own models in the scene file I would have no idea which model it is since I cannot read from your hard drive.
This is where I am asking for your input. The only way I can think of, is if you drop on my server two files. One the scene description (.scene) and one for the lego file (note that more than one ldr file might be referenced inside the .scene file). But that would also mean that you are giving me your LDraw file creation. If nobody minds that, I can go ahead and implement it. Other design suggestions are welcome.
Anyway I enjoyed implementing parts of the LDraw spec, specially the nerve-racking BFC :-)
PS. Conditional lines are not supported.
