2013-03-18, 13:08
first thank you for your work.
After a lot of years of utilization, I developed the dream of to do as many as possible of official sets with the correct parts.
I know that this dream is quite impossible and that there is similar part that can be used, but I want to try to achieve my dream.
With humility, I ask if there is someone with spare time to create some of the following parts to help me (I have tried with a conversion from LDD but the result is visually good, but in reality I do not succeed to optimize the parts so to use them properly).
Best regard and still many thanks for the part made in this year
CL
The list:
6014b Wheel 11.5mm D. x 12mm, Hole Notched for Wheels Holder Pin (the actual version is very different)
58088 Wheel Cover 7 Spoke with Axle Hole (for the set 8145 Ferrari 599 GTB Fiorano)
60032 Window 1 x 2 x 2 Plane, Single Hole Top and Bottom for Glass (for set 4997 Transport Ferry)
30625 Hinge Panel 1 x 4 x 3 2/3 with 6 holes, 2 studs on top, Locking 2 Fingers
3245c Brick 1 x 2 x 2 with Inside Stud Holder
CL
The list:
