2011-07-25, 23:43
2011-07-25, 23:53
Not quite sure what you're asking here but maybe try adding a ROTSTEP meta command? Now that I look, it seems as if Bricksmith doesn't support this command yet. You can add it in LPub though.
2011-07-26, 0:24
I found it.
view model in step mode
select step in leftside panel
double click
then you have all sorts of view option like upside down or backside
save file
open in LPub and all is good.
double click
save file
2011-07-26, 2:30
For the record, Bricksmith has supported ROTSTEP since version 2.1. As Scott figured out, the options appear in the Inspector window when you select a step.
![[Image: bricksmithrotstep.png]](http://anoved.net/images/bricksmithrotstep.png)
2011-07-26, 4:34
Ahh. Well I just did a cursory search. Don't use those commands much.
