2013-02-24, 17:07
After creating the Hips And Legs with Scale Armor Pattern, it turned out that there are at least two versions of the hips & legs pattern with different colors.
While one difference (the brown belt) is easy to see, i have a problem with identifying the color of the very dark red colored hanging cloth:![[Image: ident1.jpg]](http://www.brickshelf.com/gallery/n-man/misc/ident1.jpg)
On the same pattern, i'm not sure which color to choose for the dark armor scales. The brighter ones are "Metallic Silver" (code 80), and i took "Speckle Dark Bluish Gray" (code 76) for all the dark ones. Because the pattern of the Rohan Soldier uses the same colors, i want to be clear which colors i have to use:
![[Image: ident2.jpg]](http://www.brickshelf.com/gallery/n-man/misc/ident2.jpg)
I tried "Flat Silver" (code 179), but then the contrast between the scales seems to low.
Any suggestions?
Any suggestions?
