2013-02-15, 7:41
When I was making 10233 Horizon Express using SR3D, I found some parts were missing.
I asked the parts at 'Part Request', and I got two of them recently.
Because it was too hard for me to find where the part must be replaced by new one in text code,
I decided to use MLCAD for part replacing function.
But when I loaded 10233 file, MLCAD couldn't show my model, even though SR3D and LDview showed it correctly.
In below screen capture, you can see that MLCAD loaded the codes, but it couldn't show image: (see 10233-1.ldr)
![[Image: a0111809_511dde46d1f6e.png]](http://pds26.egloos.com/pds/201302/15/09/a0111809_511dde46d1f6e.png)
I tried to find where was wrong with my model by deleting some parts of codes one by one group,
and I could find the code group that occurred the problem. (see test.ldr)
10233-2.ldr has the codes that removes test.ldr code from 10233-1.ldr.
MLCAD shows 10233-2.ldr correctly like below:
![[Image: a0111809_511dde47af561.png]](http://pds26.egloos.com/pds/201302/15/09/a0111809_511dde47af561.png)
I am curious whether I found a bug in MLCAD 3.4, it was just a problem with my computer, or any solution for this problem.
As a reference, I installed MLCAD using All-In-One-Installer-2012-03 version and I am using windows 7.
If you have any idea, comment it, please.
Thanks for reading.
KWON
Thanks for reading.
KWON
