Full Version: Pharaoh's Quest
Pages: 1 2 3
Christian Neumann created almost all parts from this theme and I think hi will create all patterns, bat I do not see any model made from them. I think it is unfairly to ignore such hard workSmile.
I Created 7305. It is not OMR, but if some one want you can fix it.
[Image: 7305attack.jpg]
Looks like some renaming was done, you should update your LDraw library...
47753p01 -> 47753pq1
47759p01 -> 47759pq1
Attached corrected file, also - hopefully, thanks to MPDCenter - OMR compatible (a first for me Wink
And one more set 7307.
[Image: 7307duelin.jpg]
OMR compatible, changed origin/orientation and corrected reference (93249p01 -> 93249pq0)
Also unofficial file should go into the mpd Smile Who knows what happen with the current on the PT resisting files. You should not depend on that on your work. If they not change it is easy with MPDCenter to through them away once they are official. Wink
Stan Isachenko Wrote:Christian Neumann created almost all parts from this theme and I think hi will create all patterns, bat I do not see any model made from them. I think it is unfairly to ignore such hard workSmile.
Thank you! :-)
There are 3 sticker sheets left, one from the sphinx and 2 from the pyramid set, but they are really (at least the one of them is REALLY) huge and full of details. My personal goal was to create them all, because the models look somewhat "boring" without these details. I got focused on the Lord of the Rings theme meanwhile, but if you do such nice renderings, i will do the remaining patterns definitely. I like your renderings, the color scheme is awesome (seems tha i really have to learn some povray next...).
By the way, if you give me permission to edit the mummy wings which are "on hold" at the part tracker, i will fix them for certification. i do already have a corrected version, but cannot upload it without that.
You can edit all my parts if you want. I really glad when someone do it. I don't have a lot of free time so you can edit that partSmile
Oops, you're right! Now with included unofficial parts.
Thank you very much for this quick update!
Pages: 1 2 3
