2013-01-15, 22:00
Hey,
Here is the new stable LPC 1.4.6 release.
Please uninstall older versions of this software before installing a new version.
Change log:
New features:
(see full list of tickets for 1.4.6)
As always, I included a short readme.htm in the installation directory.
Cheers & Leg Godt
Nils
PS:
Remove manually conditional lines from the former file. Click on "File"->"Unload template data" and then "File"-"Import from DAT.."->"Import...projection data" to re-import the former without conditional lines.
Change log:
New features:
- The program uses now Philo's Rectifier 1.9
- You can remove previously loaded template/projection data (including lines and conditional lines) by clicking on "File"->"Unload template data"
- Pattern triangles can now overlap green projection lines! However, on overlap, the form of the imported former file will not be kept.
- The projector does not work as accurate as expected.
Cheers & Leg Godt
Nils
PS:
Philo Wrote:Hi Nils,Now, there is a workaround for this problem:
I don't want to distract you from you work on part editor but I noticed two small issues in LPC 1.4.5:
- It seems that projection on one of the triangles in the attached file is slightly off...
- Because for this, I disabled projection and used Slicerpro. I then noticed that conditional lines of the former were copied to flat projection. Not very annoying, but clearly useless
Cheers,
Philo
