2013-01-07, 17:29
2013-01-07, 22:37
I can't understand what is happening there. The CMS is working fine if you go straight to an article but not at the front page.
What confuses me more is that there don't seem to be any edits that might cause the problem.
I'm looking into the HTML/CSS side of things, but I suspect we'll need Orion to check the backend to get this fixed.
2013-01-07, 22:46
Seems to be fixed...
This was a very strange issue. I've shifted further discussion into the webmasters section to avoid muddying the forums with technical discussion.
2013-01-08, 17:14
Hey, I just saw that ldraw.org also uses CMS Made Simple
I only can imagine a fault in server configuration. But now all is fine again. That is the most important notice
2013-01-08, 22:59
It seemed to be a fault in the content block processing or caching. All I did was save a NULL change to one of the content blocks and it worked again. Was very weird.
