2012-12-19, 14:08
Hi all,
There is a strange problem going on I cannot solve.
I have added a new unofficial part to my library downloaded from the partstracker.
It concerns part 11211 Brick, Modified 1 x 2 with Studs on 1 Side.
I have put it in <LDRAWDIR>Unofficial\Parts and I use the [SCAN_ORDER] option in MLCad.ini.
However MLCad cannot find the part.
I generated a new partslist from MLCad... no succes. The part is not in the list.
So I decided to put the parts in the official parts folder and generate a new parts.lst file using good old mklist.
It ended up in the parts list just fine.
However, it does NOT show in MLCad and I cannot find it.
I have put it in my model using Insert new part and then browse for it in <LDRAWDIR>\Parts\11211.dat. It added it just fine to the model and it showed. Saving the model, closing MLCad, start MLCad again en open the file gives an error:
File 11211.dat not found! Continue loading?
Putting the part file in the same folder as my model does not help either.
How is this possible? Any thoughts?
Thanks.
Jaco
Thanks.
Jaco
