Full Version: Lego Space Collections
Pages: 1 2 3 4
A Blacktron II model. Cockpit and aircraft are detachable from the vehicle and can be attached together (included as a submodel, not part of the main one, I hope that's OK).
Unlike other models I've uploaded, I don't own this one. It uses the still-unofficial part 2515 (the wheels).
[Image: 6933.png]
A Classic Space model, with three minifigs, two smaller vehicles and a rocket, all three detachable. The arms and claws can be moved too (if you dare).
[Image: 6951.png]
All files do not have a valid .mpd name. See:
http://www.ldraw.org/article/593.html#base_file_naming
I further suggest to rotate the 6951 at 90 degree (clockwise) to be in sync with your correct assumption:
http://forums.ldraw.org/showthread.php?t...42#pid7142
Dang it, I just finished this model the other day!
Edit: Well, I'm not quite sure if his model is OMR-ready, but mine is!
Willy Tschager Wrote:All files do not have a valid .mpd name. See:
Do you mean that they should be named "6951 - Robot Command Center - Rover", "6951 - Robot Command Center - Antenna", etc.? In that case I should rename the files in other models too...
Ah, no... you mean the actual filename, not the names defined in "0 FILE" lines. I'll fix those too.
Quote:I further suggest to rotate the 6951 at 90 degree (clockwise) to be in sync with your correct assumption:
I can't make sure of it in this now (I'm at a work computer), but I believe the orientation is "correct", I just rotated the view for the picture...
I tried to comply with the OMR too... I'll check the differences when I can Smile
OK, so you've defined the different submodels in a "logical" way, to allow easier rotation/translation when needed (especially for movement or animations), whereas I just followed the instructions. Your way is more practical indeed, but is it preferred?
I may also note that at least my editor (LDCad) shows some very small overlap in the cockpit's top cover (I had to rotate it 43.9 degrees instead of 44, if I'm not mistaken), and some gaps between the minifigs' hands and arms (you could use the minifig I posted in http://forums.ldraw.org/showthread.php?t...02#pid7102).
Everything is fine now - copied to AIOI!
A quick check with MPDCenter says:
Check for: 6933 - Spectral Starguider.mpd
True - Mirrored parts free.
False - All files have correct License.
True - All Name entries are like filename.
True - Is MPD filename OMR conform.
False - All filenames in the MPD are OMR conform.
True - ~Moved to parts free.
False - Unresolved references free.
Error in: 6933 - mm.ldr Filename without setnumber does not match file description.
Error in: 6933 - mm.ldr Filename not OMR conform because of the above error(s).
basically your scheme:
0 6933 Spectral Starguider
0 Name: 6933 - mm.ldr
is not correct. This has to be either:
0 mm
or
0 Spectral Starguider
0 Name: 6933 - Spectral Starguider.ldr
Unofficial part 2515.dat not referenced correctly. Uses physical color part 302026.dat.
You use the file 2515.dat, but that is not official at present. So you have to import that file into the MPD and also the referenced subfiles.
Pages: 1 2 3 4
