2012-10-26, 19:57
Please vote on the proposal below. Please modify the Subject to include your name and vote, in addition to giving your vote in the text.
Change http://www.ldraw.org/documentation/ldraw...pping.html to add the bolded text and remove struck-through text:
Quote:This texture will remain in effect until:The texture will remain active when processing an included file unless overridden within that file.
- An END is given within the current file
- The file in which the START is located ends
- A STEP command is reached
Quote:The END command stops using the current texture and restores the previous texture to current status. This means that nested commands with START will form a stack of textures and the END command will pop those textures. However, END cannot appear in a different file from START. If an END command is given in a sub file without a START having been given in that same file, the END stops the use of a texture specified in a calling file, then that texture will be restored to use when the sub file is exitedhas no effect.
