2012-10-12, 20:15
Please vote on the proposal below. Please modify the Subject to include your name and vote, in addition to giving your vote in the text.
Change at http://www.ldraw.org/article/593.html:
to (additions in italics):
Quote:Each model in the OMR will consist of several files that are packaged together into a single MPD file. For sets that include instructions for multiple models, each model will have its own MPD file. Each MPD for the set will be named in the following manner:
<Set Number> - <Set Name>[ - <Sub Model Name>]
Where:
<Set Number>: The number assigned on the container of the set.
<Set Name>: The name of the set printed on the container in English.
<Sub Model Name>: This is Optional in most cases. This is required for alternate models that are detailed in instructions (e.g. the Creator theme). In this case the naming is left to the discretion of the author but should be descriptive of the model contained in the MPD.
<Set Number>[-<Optional Qualifier>] - <Set Name>[ - <Sub Model Name>]
Where:
<Optional Qualifier>: Is a sequential number, starting with 2.
The <Optional Qualifier> is not mandatory and gets added only if there is more than one set that could be assigned the same <Set Number>. The first set using a given number would be understood to never contain the qualifier however numbering should start with the oldest set and some investigation should be done in existing set databases.
Example:
6901 - Mobile Lab.mpd (Produced in 1980)
6901-2 - Space Plane.mpd (Produced in 1998)
