2012-10-09, 16:32
This is a proposal for changing the scoping rules for TEXMAP:
Add bolded text:
and change:
These scoping changes are critically important to implementing a hierarchical, object-oriented model to textures. It will be impossible for me to implement the standard as it currently exists. I already have a working implementation of the changes described above (*).
Allen
(*) with the exception of the stack behavior for nested textures, which is a simple enough addition
Add bolded text:
Quote:This texture will remain in effect until:The texture will remain active when processing an included file unless overridden within that file.
- An END is given within the current file
- The file in which the START is located ends
- A STEP command is reached
and change:
Quote:The END command stops using the current texture and restores the previous texture to current status. This means that nested commands with START will form a stack of textures and the END command will pop those textures. However, END cannot appear in a different file from START. If an END command is given in a sub file without a START having been given in that same file, the END stops the use of a texture specified in a calling file, then that texture will be restored to use when the sub file is exitedhas no effect.
Allen
