I fear that this will be a difficult task to find out because nowhere there is a tracker for parts renaming as long as the parts are not official.
I would try to identify the missing parts by substituting those numbers by another existing part, so you can see the location in the model. With a look into the building instructions and the inventory (
http://www.peeron.com/inv/sets/8070-1) it should be possible to find out which parts you are searching.
Just an idea to solve your problem.
One of the missing parts is a
Technic Shock Absorber 6.5L, Spring. I finally found it using LeoCAD's pieces library manager, it's now 22977 ~Spring for Technic Shock Absorber 6.5L Extra Stiff. But why don't the tilde parts show up in either MLCad or SR 3D or LeoCAD in the parts browser? How do I add them to a model?
I did manage to replace the x882 with the 22977 using the modify option in MLCad's right click menu. I'll try to hunt down the other ones.
Why does this have to be so complicated? Wouldn't it just be easier to not delete renamed/obsoleted/whatever parts and add a comment that you should use part xxxxx now instead of this one?
I think it is like this:
u9112.dat is renamed to 59143.dat
u9113.dat is renamed to 59142.dat
s\58124s03.dat is a file present in the official library.
All three are included in part 58120.dat, "Electric Power Functions Medium Motor"
x882.dat is renamed to 70038.dat. It's included in shock absorber 73129.dat
Thanks, I renamed them all, and SR 3d now opens the model, but MLCad still complains about 58124s03.dat? Why?
It's a subfile. Add "s\" to to your file. Like this: s\58124s03.dat
This again (and again!) shows how useful an history of parts renames during unofficial stage would have been, and would still be. Something as rudimentary as a plain text log file would save a lot of disappointment and frustration.
The log file exists and is used to populate the
activity log. I'll check how easy it would be to provide a search capability.
That would be a great improvement if this data was accessible! Thanks in advance
