2012-09-10, 7:08
Hey,
Here is the "answer to the Ultimate Question of Life, the Universe, and Everything": LPC 1.4.2
Please uninstall older versions of this software before installing a new version.
Your configuration won't be deleted if you have already version greater than 1.3.1 installed on your machine.
Change log:
New features:
(see full list of tickets for 1.4.2)
I included a short readme.htm in the installation directory.
Cheers & Leg Godt
Nils
Change log:
New features:
- You can deselect objects with the selection rectangle while pressing CTRL.
- You can copy+paste the transformation matrices or vertex coordinates with 1 click.
- You can toggle the visibility of the BG image (with Ctrl+B).
- You can use a shortkey to dis-/enable the grid (Ctrl+G) / axis label (Ctrl+L).
- The previous mode will be restored after closing the preview.
- You can use a recent file list.
- The French language file is improved.
- The file loader crashes because of side-effects from 1.3.8.
- Zoom with +/- does not work in preview mode.
- The program crashes when a single group was created, deleted and saved.
- Other minor bugs.
Cheers & Leg Godt
Nils
