2012-09-08, 22:30
Hello Travis,
I just discovered that sometimes LDView creates syntactically invalid .pov files on export.
The problem seems to be triggered when you're rendering a file from your LDRAW "models" folder
which references a primitive located in a folder called "48" inside that "models" folder.
What happens in that case is that the resulting .pov file contains a line
Note the leading "48/" in the identifier, which is illegal.
Note that LDView seems to substitute the substring _slash_ for / already,
but that seems to fail in some cases.
I've attached my test file plus its .pov output file here for your reference.
- Steffen
#declare 48/LDX_48_slash_t04q4444_dot_dat_in_part = torus // Torus 0.25
- Steffen
