2012-08-25, 20:18
Currently I am working on an app that uses much the OMR Spec.
So I need to fully understand it.
I have a problem with the following content:
So far i remember is the 0 FILE entry the in the MPD file the file name for the code that follows until next 0 FILE entry or...
In the above it is stated that the 0 FILE entry contains the modified file name and the rest should be like the original DAT-file. If I strictly follow that I would have a 0 FILE entry that is different from the 0 Name entry.
According to the MPD Spec those both entries should be the same!
I am currently confused !
Please help me.
Each individual model file in the MPD that represents an unofficial part must use the standard header format of unofficial parts on the parts tracker. Its 0 FILE entry will reflect the modified MPD version of the part's filename, but the rest of the header will reflect the original filename.
Please help me.
