Full Version: Technic Part Request (Anchor)
This is an anchor for technic part request for me or anyone who loves technic.
http://www.bricklink.com/catalogItem.asp?P=10197
[Image: 10197.jpg]
Technic, Axle and Pin Connector Hub with 2 Axles
Thanks for reading Smile
http://www.bricklink.com/catalogItem.asp?P=95292c01
[Image: 95292c01.jpg]
Technic, Shock Absorber 9.5L, Complete Assembly (Extra Hard Spring)
Thank you Smile
http://www.bricklink.com/catalogItem.asp?P=99012
[Image: 99012.jpg]
Technic Rotor Blade Small with Axle and Pin Connector End
Thank you Smile
http://www.bricklink.com/catalogItem.asp?P=99013pb01
[Image: 99013pb01.jpg]
Technic Rotor Blade Large with 3L Liftarm Thick and Black Rubber Tip
Thank you Smile
http://www.bricklink.com/catalogItem.asp?P=111b
[Image: 111b.jpg]
Technic, Axle and Pin Connector 3 x 3 with Axle
Thank you Smile
http://www.bricklink.com/catalogItem.asp?P=56908
[Image: 56908.jpg]
56908 Wheel 43.2mm D. x 26mm Technic Racing Small, 6 Pinholes
Thank you Smile
Hey,
it should be done: 10197.dat
Rolf
Hi
Thanks for your concern Smile
Thanks again
Kwon
Thanks for information.
I didn't know that 111b and 58177 are the same part.
Thanks again
Kwon
Your welcome,
please watch out for the part at the parts tracker. Its orientation has already changed Smile...
Rolf
I need this part to complete 9396 that has been almost done.
[Image: a0111809_5018883443055.png]
[Image: a0111809_5018883400941.png]
[Image: 99499c01.jpg]
http://www.bricklink.com/catalogItem.asp?P=bb571c01
---> http://www.bricklink.com/catalogItem.asp?P=99499c01 (Changed part number)
Electric, Motor 9V Power Functions L with Dark Bluish Gray Bottom
Please, make this part as soon as possible.
Thanks for reading. Smile
[Image: 99498c01.jpg]
http://www.bricklink.com/catalogItem.asp?P=bb572c01
---> http://www.bricklink.com/catalogItem.asp?P=99498c01 (Changed part number)
99498c01 Electric, Motor 9V Power Functions Servo with Dark Bluish Gray Bottom
http://www.bricklink.com/catalogItemPic.asp?P=8448stk01
[Image: 8448stk01.gif]
Able man in the world!! convert this sticker to LDraw parts, please.
I plan to do the PFS large and Servo motors, but these complex shapes takes time Wink
Great! I am happy to hear good news!
I can wait!
Thank for your work Wink
http://www.bricklink.com/catalogItemPic.asp?P=8880stk01
[Image: 8880stk01.jpg?0]
[Image: a0111809_5044a8073b02b.png]
I found some ldraw sticker parts for 8880 except for on the nose of the car. (next to V8 horizontal black stripes in yellow)
Anybody know where the sticker is?
Servo motor is done!
[Image: 99498.png]
Thank you so very much alot Smile
The time to assemble Crawler is coming if bb571c01 was made.
http://www.bricklink.com/catalogItemPic.asp?P=93575
http://www.bricklink.com/catalogItem.asp?P=93575
I need this part to complete 10227 B-Wing.
Please, An able-man make this part as soon as possible.
[Image: a0111809_506cd39a3c874.jpg]
...and large motor too:
[Image: 99499.png]
Working on both rotor blades...
GREAT!!!
Thank you ♬♩♪ Smile
Thank you ♬♩♪ Smile
Thank you ♬♩♪ Smile
Thank you ♬♩♪ Smile
You are my hope, my savior ! Wink
Wink
Rotor blades are both available now, but there's a question about their orientation, which may change...
http://www.ldraw.org/cgi-bin/ptdetail.cgi?s=99012
http://www.ldraw.org/cgi-bin/ptdetail.cgi?s=99013
You always give me happiness.
THANK YOU SO MUCH Smile
Working on it...
Thanks alot Smile
Done! Phew :p
[Image: 56908.png]
Great Job ^^b
Thank you very much Smile
[Image: 32494.jpg]
http://www.bricklink.com/catalogItem.asp?P=32494
32494.dat Technic, Steering CV Joint
I can't find this file at part tracker yet.
KWON
[Image: 11950.jpg]
http://www.bricklink.com/catalogItem.asp?P=11950
11950 .dat Technic, Steering Portal with 2 Pin Holes
KWON
[Image: 11949.jpg]
http://www.bricklink.com/catalogItem.asp?P=11949
11949.dat Technic, Steering Portal with 2 Pin Holes and 2 Ball Joint Arms
KWON
Hi KWON,
32494 is official since 2009. The two other parts are on my to-do list, but I'm presently very busy (at least till May) with EV3 stuff...
Oh-Seong KWON Wrote:32494.dat Technic, Steering CV Joint
That's because it's in the official library instead. Time to update? Smile
EDIT: oops, beaten to it by days. I'm still blind. Sad
Thanks for comment Smile
I am glad that you are aware of these two part Smile
This one is done!
[Image: 11950.png]
Great! Thanks alot Smile
Phew Tongue
This one was tough...
[Image: 11949.png]
Thank you s~~~~~~~~~~oooooo much !!!! Smile
Everyone forgot about http://www.bricklink.com/catalogItemPic.asp?P=93575.
I am to busy last time, so I have no time to do it, but hope someone haveSmile
