2012-07-09, 16:26
Hey,
Here is the fresh LPC 1.3.9 !
Please uninstall older versions of this software before installing a new version.
Your configuration won't be deleted if you have already version greater than 1.3.1 installed on your machine.
Change log:
New features:
(see full list of tickets for 1.3.9)
I included a short readme.htm in the installation directory.
Cheers & Leg Godt
Nils
Change log:
New features:
- You can use a spline tool for creating spline curves.
- You can save your data in a LPC - V1.00 legacy format. This format will be read by all LPC versions, but it does not store all pattern information (e.g. metadata, primitives and groups).
- You can switch between the selection of overlapping primitives while CTRL is pressed.
- You can zoom with '+' and '-' too.
- The zoom textfield shows the zoom dialog with just one click.
- The F5/F6 toolboxes are movable.
- Overall program stability, compatibility and performance is improved.
- The sticker dimensions are not correct.
- It is impossible to select a primitive/​group, which is transformed into a straight line.
Cheers & Leg Godt
Nils
