Full Version: Part number bb278
Hello everyone,
my name is David and i want to design an educational model with 9686 set (http://www.bricklink.com/catalogItem.asp?S=9686-1).
I don't be able to find any of the figures in bb278 sheet.
here it is a link to BrickLink for this sheet:  http://www.bricklink.com/catalogItem.asp?P=bb278
Anyone can help me? Any idea where can I find them?
Thanks in advance.
David
Hello David,
These parts would be very easy to create (at least a flat version)... provided we get the dimensions! If you have the parts and a flat bed scanner, post here a scan of these parts (no need for ultimate resolution, 200dpi is enough), I'm sure someone will create the LDraw models.
Note - I have the panels from 7471 Mars rover set, they are 1.5 ldu thick.
Note2 - proper design number for bb278 is 57046 (item 4493536), 7471 Mars rover set is 47521 (item 4207646) - Thanks, Joshua!
Hello Philippe,
I scan all the pieces of the bb278, in A4 size (21x29 cm). You can find in the next link.
https://picasaweb.google.com/10642985434...directlink
In other hand, i can't find 57046 in LDraw parts tracker.
Thanks again.
David G. Wrote:I scan all the pieces of the bb278, in A4 size (21x29 cm). You can find in the next link.
Looks perfect! but (I'm not used to G+), how do I download the full resolution image, it seems I can only get a reduced size image, instead of your original full size one?
Quote:In other hand, i can't find 57046 in LDraw parts tracker.
I meant, when the parts are done, they will get this part number as base (57046a, 57046b... and so on).
Philippe,
It's forbidden attach jpg file format in the forum. I put it with .dat, but you must to rename to .jpg to open.
Thanks.
Here is the first one...
[Image: 57046b.png]
I finally named it "b" because it's the medium sized triangle. Attached the LPC file I used to create it, maybe it will be useful to other guys: I'm kind of busy these days, so I hand on the torch to anyone with some more free time...
Ohh!! what a fantastic job.
Thanks very much. I tried to do something like this but was a disaster.
Finally created the two other triangles...:
[Image: 57046a.png]
[Image: 57046c.png]
Thanks very much Philippe. You done a great job.
I can now develop the documents for my students with all the pieces.
Thanks again.
[Image: 57046d.png]
The description has to be changed to match with its current dimensions. Honestly, I don't know which unit I should use for that purpose..
