Full Version: Does 32125 still need rewrite?
I've seen this on the list for a while, with CCAL 2.0 in the header, but still needing work.
Anyone mind if I re-address this?
Given the irregularity of comments I say Just Do it.
I figured as much - here's the work in progress, will measure split above the axle hole when I get home this weekend and move symmetrical geometry to sub-files.
A note on the hex-ring (current 32152s02.dat) if anyone wants to make this a primitive and use it, grab it. It won't work with the split above the axle hole, so will be reusing s02
UPDATED: REMOVED WIP - UPDATE SUBMITTED.
Yes, please. This is the last remaining Non-CA authored part. Let's finish the re-write and finally kill the Non-CA section of the official library.
Update submitted.
