2012-06-12, 21:15
Hi everybody !!!
After more than 2 months of inactivity, here is my new release of the application. Hope it worth the awaiting!
A lot of new functionality added in model management this time. You will find them in Groups context menu and in File menu.
Read the following: You won't miss this !
Available as always from http://sr3dbuilder.altervista.org/
Please feedback for malfunctioning and hints, especially from registered users...
Sergio
0.7.1.5 - Changes to previous version (2012.06.12)
Fixed
- Instruction Miner should now work faster and with a lot of less bugs
- Showing/Hiding the "Model" group with no parts in it causes a crash
- Importing model causes no longer Pause Instructions lost
- Many group management bugs fixed
- AutoOrient option sometimes does not correctly aling grid
Changed
- Importing a model causes a NEW group with the model file name being created
- Some less used Selection Option are now grouped in a dropdown button
- Hierarchic hide/showing model is now faster (and safer)
- The Instruction Miner window is now resizeable
Added
- Save a group/subgroup to model file (registered version)
- Importing model with groups
- Analyze a single group/subgroup into Instruction Miner
- Clone a group/subgroup (registered version)
- Allow the Instruction Miner to show only parts above your curson allowing a better model analysis
- Group Reference Brick to allow quick positioning/connection of a group/subgroup
- You can now move Groups and SubGroup across the Group tree
- Group tracking while hovering groups tree
- Added <CTRL-G> accelerator to show Group tree
- Select parts by shape
- Save your current selection to a new model (registered version)
- Exporting to .DAT functionality including definition for Flex parts.
Notice: a very big file is generated, but you can open it from lDView to create the .pov file for POV-Ray
rendering. The flexs have BAD behavior in lDView but will render fine in PovRay
A manual update will follows in next weeks. Just the time to write it !
Sergio
Fixed
Changed
Added
