Is there a way to "group" Torsos (Torso + 2 Arms + 2 Hands) and Legs (Hips and 2 Legs), so LPub counts them as 1 Part (and shows them as that in the part window) instead of 5 or 2 separate parts? I tried the "group" function in MLCad without knowing what it really does but that didn't work in LPub. I don't like using shortcuts, because I want to be able to modify the parts without editing the dat. And I would have to add the modified dat to my model so others can see it.
Put the assembly you want into a separate *.ldr or *.date file e.g. in the MODELS or "Unofficial\PARTS" folder,
then use it in your model. I think LPub then should treat that as an unofficial, but standalone part, I hope.
It is possible in LPub to replace a group of parts by another assembly in BOM and PLI:
0 !LPUB PLI BEGIN SUB <part> (<color>)
(parts)
0 !LPUB PLI END
For example,
0 LPUB PLI BEGIN SUB turntable.ldr
1 8 0 0 0 1 0 0 0 -1 0 0 0 -1 48452.DAT
1 0 0 0 0 1 0 0 0 -1 0 0 0 -1 48168.DAT
0 LPUB PLI END
puts the image of an assembled turntable instead of two separated halves (turntable.ldr contains the two lines
1 0 0 0 0 1 0 0 0 -1 0 0 0 -1 48168.DAT)
Or:
0 LPUB PLI BEGIN SUB 76537.dat 14
1 0 100 110 0 1 0 0 0 1 0 0 0 1 4254.dat
1 14 100 0 0 1 0 0 0 1 0 0 0 1 4255.dat
1 494 100 56 0 1 0 0 0 1 0 0 0 1 22977.dat
0 LPUB PLI END
substitutes a shock absorber shortcut to its detailed equivalent in code (that could for example have its spring compressed.
ah, cool! something new for me to learn!
Philippe \Philo\" Hurbain Wrote:It is possible in LPub to replace a group of parts by another assembly in BOM and PLI:
(parts)
0 !LPUB PLI END
For example,
0 LPUB PLI END
Or:
0 LPUB PLI END
Has "turntable.ldr" (in my case "hipsnlegs.ldr") to be defined somewhere else in the mpd? Because all that happens when I add the lines
0 LPUB PLI BEGIN SUB hipsnlegs.ldr
1 0 0 32.464 3.307 1 0 0 0 0.96 0.28 0 -0.28 0.96 3815.dat
1 0 0 44 0 1 0 0 0 0 1 0 -1 0 3816.dat
1 0 0 44 0 1 0 0 0 0 1 0 -1 0 3817.dat
0 LPUB PLI END
is that the PLI is gone (See step 1 in the picture)
![[Image: 7320199528_ac2d7f4e7d_h.jpg]](http://farm8.staticflickr.com/7098/7320199528_ac2d7f4e7d_h.jpg)
Mmhhh... not tested in an MPD. I simply put the substitute part for bom in the same folder as main file.
