2012-05-02, 17:18
Hey,
Here is the new LPC 1.3.4.
Please uninstall older versions of this software before installing a new version.
Your configuration won't be deleted if you have already version greater than 1.3.1 installed on your machine.
Change log:
New features:
(see full list of tickets for 1.3.4)
I included a short README.pdf in the installation directory.
Cheers & Leg Godt
Nils
Change log:
New features:
- The program imports subfiles of primitives
- The projection data import now parses linetype 2 and 5
- DAT filenames with spaces are supported
- You can press the Ctrl+C/X/V or Del key to change the text displayed in on-screen textboxes
- It is impossible to group triangles which are adjacent to an existing group
- The subfile import does inline all required subparts/primitives of the subfile
- The highlight around a selected triangle that exactly match a template triangle is shown
- Vertices from projection data remain locked
- LPC crashes if the user sets a custom colour in the toolbar which is not defined in LDConfig.ldr
- LPC crashes if the user makes excessive use of the "Merge to nearest line" functions.
- The undo/redo functions crash the application under certain circumstances and deform a pattern.
- It is possible to group triangles which are adjacent to an existing group (misfeature).
Cheers & Leg Godt
Nils
