Full Version: TK-949's Star Wars Models
Pages: 1 2
I'm trying to recreate all Star Wars Models (except the ugly Technic and Mindstorms stuff) from 1999 till today. All models should be OMR compliant, some, like the Snowspeeder, need work since they require functions I haven't learned yet, like repositioning a part from one step to another, for example. If there are any errors, please tell me, so I can correct them.
Each Model will be posted in a separate posting inside this topic. The pictures shown may contain parts that differ from what you'll see, when you open the model. These are officially available parts which I rewrote and which are still, or soon will be, on the PT. So there's no need to add these to the model itself.
Due to a bug, the files are not working in LPub. In order to make them work you need to open them in a texteditor and search/replace
0 !LDRAW_ORG Unofficial_Model
with
0 whatever
if you want to replace it again when you're through with LPub, if not, just delete these lines.
Daniel,
Daniel Görner Wrote:like repositioning a part from one step to another, for example.
Check out the instructions for the "916 - Atmosphere Cruiser" at:
http://www.holly-wood.it/building_instructions-de.html
and study how I used the Buffer Exchange feature in MLCad. On the other side it is not necessary to mimicry a real BI. Most sets I included in the AIOI just uses simple steps.
7101 - Lightsaber Duel
1999
50 Pieces
2 Minifigs
Contains 1 unofficial part
[Image: 6983336270_797465d272_b.jpg]
OMR compliances looks fine - though I just had a very short glance at the file. However the spec for unofficial files has changed. please read:
http://forums.ldraw.org/showthread.php?t...50#pid4350
7110 - Landspeeder
1999
47 Pieces
2 Minifigs
[Image: 6984668382_bc344947d2_b.jpg]
Changed.
7111 - Droid Fighter
1999
62 Pieces
Contains 1 unofficial part (including 1 unofficial subpart)
[Image: 6984859884_697eaffa48_b.jpg]
7121 - Naboo Swamp
1999
81 Pieces
4 Minifigs
Contains 2 unofficial parts
Missing x116 Jar Jar's Head, replaced it with equally annoying Dobby.
[Image: 7131413487_c981cab3fc_b.jpg]
Copied to AIOI. Thanks for sharing!
7128 - Speeder Bikes
1999
90 Pieces
3 Minifigs
[Image: 7232308330_cb6779290d_b.jpg]
Pages: 1 2
