2012-04-08, 17:15
Hey,
Here is the new and fast LPC 1.3.2.
I do not recommend to continue using the previous version 1.3.1 due to the massive performance and stability improvements I have included in this release.
Please uninstall older versions of this software before installing a new version.
New features:
From now on the undo/redo history will be cleared if you start a new pattern.
Fixed Bugs from 1.3.1:
New features:
- You can save with one click on the toolbar floppy icon.
- You can merge a vertex to a triangle/template border (with the new functions in the “Merge/Split..” menu).
- You can deactivate the triangle overlap detection when it's active (just click on the menu entry again).
- You can keep your Config.cfg file (this file stores all your settings) after you have uninstalled the LPC and use it for future versions of this program.
- The "very fast triangulation" will prevent the generation of malformed triangles.
- The DAT import will now recognize deprecated ring#.dat/ring##.dat primitives.
- Post progressing will be done with Rectifier 1.8
- The drawing performance is improved and overall performance was improved. The “Performance Mode” should be superfluous.
- Several language translation bugs
- Filled triangles disappear when all vertices aren't placed in the viewport
- "CSG rotate" does not update the internal data structure
- Fatal undo/redo errors
