2012-03-30, 16:26
Hey,
Here is the new LPC 1.3.1.
I do not recommend to continue using the previous version 1.3.0.
Please uninstall older versions of this software before installing a new version.
Change log:
New features:
(see full list of tickets for 1.3.1)
I included a short README.pdf in the installation directory.
Cheers & Leg Godt
Nils
Change log:
New features:
- You can round the coordinates of the current selection from 0 to 3 digits.
- Select connected/touching with same colour now using the colour of the triangle which was last selected.
- The vertex data group box won't refresh when selecting another single vertex with the selection box.
- CTRL do not remove the vertices from the selection when triangle mode is activated.
- CTRL do not remove the triangles from the selection when vertices mode is activated.
- I include Rectifier 1.4 but it should be 1.7
- The initial Config.cfg contains a malformed path to the language-.csv.
- The title from the "Save as..." dialog contains a "&"
- One i18n bug in the advanced option menu (The "Colours:" Tab)
Cheers & Leg Godt
Nils
